2012 WRX CEL & possible boost leak
Results 1 to 4 of 4
This is a discussion on 2012 WRX CEL & possible boost leak within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So my engine idles rough, and recently my CEL came on. I'm getting three codes P0102 - Mass or Volume ...
    Dec 2015
    P0102 - Mass or Volume Air Flow Circuit Low
    P0304 - Cylinder 4 Misfire Detected
    P0113 - Intake Air Temp Sensor Circuit Malfunction (High Input)
    I brought it to the dealership and they swapped the coils and plugs with cylinder 2, which did not solve the problem. They also performed a leakdown which came back at 6%. They said that was "a little higher than normal".
    I bought a Cobb AP and sent in a datalog for Cobb to look at. They said AF Learning 1 is adjusting fuel trim in a way that suggests I'm running rich, and that I'm underboosting. Apparently these characteristics together almost always indicate that there is a boost leak in the intake tract, and a common failure point is the pre-throttle body hose, so they recommended I replace that. I looked into AF Learning 1 and it could be doing this due to a bad or dirty MAF sensor or a bad front O2 sensor.
    I get the feeling all of this is related, but I really have no experience in this area.
    I've read Donkey's thread on misfires. My current plan is to replace the throttle body hose and clean the MAF. I guess I'm wondering if anything else should be done first, or what I should do after. Also, I had the code cleared, and it stayed off for roughly 1000 miles. When my car was idling for an extended period is when the code came back on.
    Everything is stock.
    Water.....sometimes waves rqjoe's Avatar
    Feb 2015
    Ohio
    Initial thoughts are that if it were an actual 'bad' O2 sensor or dirty MAF sensor, you would not have gone those 1000 miles without the CEL coming back on.
    Dec 2015
    That's a good point. Hadn't really thought about it that way. Hopefully sorting out the boost leak will clear things up.
    Dec 2015
    I am haveing the same issue with my 08 wrx if you solve the issue please let me know how you did it and if I figure it out I'll post it in here
