broken airbox broke bolt. help!
Results 1 to 10 of 10
This is a discussion on broken airbox broke bolt. help! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey guys. I just bought my first brand new 2016 about 2 weeks ago. Came from an RSX. Anyways. I ...
    Registered User jayyboogie's Avatar
    Sep 2015
    Hey guys. I just bought my first brand new 2016 about 2 weeks ago. Came from an RSX. Anyways. I was replacing the boomerang lights the other day and as I was loosening the airbox bracket, one of the bolts broke loose. Now I'm fu*ked. There is still another screw to hold it in place. However, with my paranoia, I'm. Afraid that the bracket becomes loose and eventually have a loose airbox that may lead to something worst. Any suggestions? I tried try drill it out and extracting it, but there is no access to the other side (top of the bolt). Anyone k ow how to get to the other side of the bolt or have experienced the same issue?
    Sep 2015
    This is the srew
    For External Use Only irickchad's Avatar
    Sep 2013
    WV
    You still have another entire stud and nut holding it in, don't worry about it.
    I have an STi with an intake and no tune, I never change my oil, and my wheel spacerz are mad tyte.
    Sep 2015
    Yea. I'm not worried about the other bolt falling off. I'm worried if the bracket loosens and tilts over one side. Causing the airbox to grind of melt from touching metal.
    Water.....sometimes waves rqjoe's Avatar
    Feb 2015
    Ohio
    so to me that does not look like a screw or a bolt. It looks like a stud. that means no access to the other end. How the heck did you do that? You say you tried to drill it out but I see not drill marks on the broken stud? Did you actually try? Or just think about trying? If it were me, I think I'd drill a hole right beside the bad one, tap it, and put a new bolt in. Don't need one as large a diameter as the bad one either.
    Sep 2015
    Quote Originally Posted by rqjoe View Post
    Yea I tried.. that was a picture before I tried drilling it. Had an ballast mounted there but it was dangling and making noises when I drive so I went to remount it but it appears that it might have been over tightened. As I turned to loosen with a socket. It snapped off. That's not a bad idea. I was thinking about that earlier today... to just drill another hole. But I wanted to see if there's anyway to remove it first.
    Sep 2015
    Well.. got it fixed today and man am I happy!
    Feb 2017
    Quote Originally Posted by jayyboogie View Post
    Sorry to resurrect an old thread -- if you're still around to answer, how did you fix it? Did the screw stud stuck in the socket come out easily with drilling?
    lit fam XJman's Avatar
    Feb 2015
    At work
    How is everyone breaking this off?
    All? NO ALL!
    Feb 2017
    Quote Originally Posted by XJman View Post
    Careless me torqued too hard. But, it didn't need much force to break it. If not a torque wrench, a socket driver would be safer than a socket wrench.
