Broken bolt!!!! NNOOOOOO!!!!!
Results 1 to 15 of 17
This is a discussion on Broken bolt!!!! NNOOOOOO!!!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey guys and gals! So problem of the day! I am in the middle of doing my timing belt and ...
    Mar 2015
    Pueblo, Colorado
    Hey guys and gals! So problem of the day! I am in the middle of doing my timing belt and when I went to go put the new smallest pulley on and when I torqued it to 13Ib the bolt snapped on me. Probably my fault but now I have a broken bolt in the engine that is kinda important. Anyone have any good ideas? Can I replace the whole part of I cannot get it out? Here are some pictures.
    Mar 2015
    Pueblo, Colorado
    Sorry I was having troubles uploading pictures!
    I don't think there's a part to replace. Is there?! I think you'll have to remove the bolt.
    - Al Stewart
  5. #4
    Registered User 100plus2Vegas's Avatar
    Mar 2014
    Oceanside,Ca
    Take it to a welding\muffler shop. They can weld a washer to the bolt. Weld a nut to the washer. Use a liberal amount of penetrating oil and work it back and forth with a wrench till it frees up. Then remove it.
    14 sedan: Protune: 318AWHP 344ft lbs up pipe, Tial EWG, AEM intake, Cobb AP V3, 3" TBE, Avo FMIC, Turbo Smart bpv, Aem air fuel gauge,Cobb knob,Perrin Pitch Stop mount, SPT front strut tower brace, K-Sport coilovers@1.5" drop. Eibach sways, Perrin Spherical end links, Cusco subframe brace, White Line sway braces, Perrin sub frame bushings.
    07 Duramax LBZ- 26psi,intake, TBE, Diablosport programmer, Edge Insight with EGT, EGR block off, BD exhaust manifold, PPE fuel valve.
  6. #5
    I wonder why the bolt would snap with such low torque also. Would it be worthwhile to replace all the bolts at this stage? Or at the very least check the threads for that bolt on the block very carefully?
    - Al Stewart
  7. #6
    Set Phasers to Stun jfisch822's Avatar
    Sep 2014
    Greenville, SC
    Was the engine hot when working on it? If so the bolt may have cross threaded in the already soft aluminum. Or if the engine was hot the threads could have been damaged when removing the bolt in the first place. Just an idea.
    Stink-Eye Mob #864
    My Garage:
    2013 WRX Hatch ISM - "Scrappy" - http://www.clubwrx.net/forums/builds...wrx-hatch.html
    2004 Forester 2.5XS
    "Turbos: Exhaust gases go into the turbocharger and spin it, witchcraft happens and you go faster" - Jeremy Clarkson
  8. #7
    Sep 2014
    Greenville, SC
    Also if you don't have a welding shop nearby, a bolt extractor may be able to get it out if it's not too tight. Just drill a hole in the bolt and then left hand extractor will pull the bolt.
    Stink-Eye Mob #864
    My Garage:
    2004 Forester 2.5XS
  9. #8
    Water.....sometimes waves rqjoe's Avatar
    Feb 2015
    Ohio
    Use a center-punch to tap the center of the bolt. Then drill into it. Then use an easy out. Looks like you have room to do that. If it is only 13 ft-lb, you should be able to get it out. I have heard of using a 'cold-spray' freon type can to shrink bolts once drilled immediately before inserting easy-out. Only spray the bolt though, not the surrounding engine. Conversely you could heat the surrounding engine area but that is tough to do with aluminum since it transfers the heat so quickly.
  10. #9
    Mar 2015
    Pueblo, Colorado
    Thank you for all the replies guys! I don't have a good shop to take it too also would prefer not to get it towed. I want to try the easy out method but the only issue I'm having is the part that is sticking out of the engine is not a flat surface and I'm having a hard time sanding it to punch it for the drill. Does anyone have any ideas on getting it flat? Do I need to make it flat?
  11. #10
    Mar 2015
    Pueblo, Colorado
    Also I'm a little nervous about my torque wrench now. It's one from harbor freight should I get a new one?
  12. #11
    Sep 2014
    Greenville, SC
    Quote Originally Posted by JasonLevinson1 View Post
    That broken end of the bolt doesn't need to be flat, you just need a good punch and a hammer. Get that punch mark as close to the middle of the bolt as possible and get a good mark. This is needed so that when you start to drill into the bolt the drill bit doesn't walk across the surface, it stays in the punch mark and drills into the bolt.
    Stink-Eye Mob #864
    My Garage:
    2004 Forester 2.5XS
  13. #12
    Mar 2015
    Pueblo, Colorado
    Ok I got 2 different punches 1 bigger and one smaller. Having a hard time getting leverage with the hammer to get a good hit. Also went and got a better torque wrench and better bolt so hopefully once I get this out it will be smooth from them on. Should I replace all the pulley bolts?
  14. #13
    voidin warranty since 05 unseen's Avatar
    Jan 2015
    631 to 516
    drive it to a machinist and have him (or her, in case calsarah is reading this) dye it out. or is it tap? whichever, have him pull that sucker out. just have the OEM replacement bolt ready. this happened to me once when i over torqued a manifold bolt. maybe not as detrimental as yours but still.
    stinkeye member #976
    2014 wrx hatch build
    http://www.clubwrx.net/forums/builds...een-build.html
  15. #14
    Mar 2015
    Pueblo, Colorado
    There's not timing belt or radiator on the car so it's not drivable. Sadly the day I decided to start my timing belt my radiator broke as well! So I'm waiting on a new radiator to come in! But good news!!!! I got it out without tapping it! I was able to get ahold of a very small part on the top of the bolt after trying to put a hole In The top and I was able to just slowly turn it out!
  16. #15
    Mar 2015
    Pueblo, Colorado
    Thank you guys for the help! Should I get new bolts for all the pulleys?
