Car won't start out of no where.
Results 1 to 3 of 3
This is a discussion on Car won't start out of no where. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Have had my 09 from the dealer with little to no problems. Friday i drove about 80 miles round trip ...
    Registered User wrx1234's Avatar
    Sep 2009
    Dover DE
    Have had my 09 from the dealer with little to no problems. Friday i drove about 80 miles round trip and parked the car. Got in turned the key all the electrical turned on and when i turn the key all the way over i hear a humm from behind when i think is the fuel pump, other than that no other noise. I checked all my connections and tried to use jumper cables to start it with no luck. I also checked the fuses and the battery is good. I checked to see if i had any trouble codes and the car came out clean. I had my wife push it with her car (had to get home) and i was able to get it started by popping first gear with the push. and it ran fine, but once it was shut off at home it did not start again.
    Any ideas?
    2009 WRX - Catted DP, Torqued performance stage 2
    2011 Sportwagon TDi
    1970 Chevy Impala Convertible 454
    Aug 2012
    Tucson, AZ
    If the battery, grounds, and charging system are perfectly fine, which assuming they are since the fuel pump turns, check your clutch switch or adjusting the switch or clutch pedal
    Sent from my SCH-I545 using Tapatalk
    Hawkeye Alliance 520
    Previous cars:
    2010 Mitsubishi Lancer (sold)
    2009 WRX (sold )
    2013 Scion tC (sold)
    2008 Audi A4 (Totaled)
    Photographer/storm chaser
    https://www.facebook.com/kevinrimphoto
    IG - kevinrimcoski
    Sep 2014
    Also check the starter relay.
