Hi all so today and yesterday are the first days I've gotten on my car since owning it new. I notice when shifting from first to second with throttle to the floor and clutch fully disengaged I get about one second before throttle goes back to wide open. It just feels like a quick Hesitation then kicks back into throttle. Normal? It's almost like I'm shifting to fast or something. I'll bet if I slowed down it would stay. But seems irrelevant to the situation. Just wondering what I could try. I got the access port today and am running a stage 1 93 octane map. It does it with the map and it did it before the ap. Looking for any ideas. Maybe I just suck at shifting this car and need more practice? It's different response than a lot of other manual cars I've driven. Thanks guys!
I'm hoping you have more than 1000 miles on the car if you're doing tunes and WOT shifts lol. If not, you need to follow the break in period and drive under 4k rpm at varying speeds until you hit 1000+ miles.
Sweet deal! As Irickchad mentioned above, it is probably the clutch slipping on the WOT hard shifts. I drove a couple manual cars that exhibited the same behavior.
I personally think the clutch and pressure plate still need a little more time to break in before they can handle the WOT fast shifts. But, I very well may be wrong. If that's the case, you should have the dealer check it out to be safe.
I have the same car and mine does the same thing 1st through 3 it's like it's not getting enough air or fuel just wondering if you ever figured anything out on yours
