which line to plug on intake inlet and/or purge control valve?
Results 1 to 8 of 8
This is a discussion on which line to plug on intake inlet and/or purge control valve? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; im getting 16.8 psi when target boost is 18 psi. thought it was close enough, but heads here were nice ...
    rocking hater blockers unseen's Avatar
    Jan 2015
    strong island
    im getting 16.8 psi when target boost is 18 psi. thought it was close enough, but heads here were nice enough to let me know this may not be the case. so in addition to just having piece of mind, i would like to run a boost leak test. boost leak tester will go on intake inlet, and i was just wondering which of these need to be plugged as well? or anything else that needs to be plugged.
    for reference to my pic:
    green arrow is to intake inlet
    red circles are to intake inlet
    blue circles are to purge control (i believe, correct me if im wrong)
    thanks for you help guys.
    stinkeye member #976
    Supporting Member livid_wrx's Avatar
    Mar 2014
    South East Michigan
    That's a odd green.
    Jan 2015
    strong island
    Quote Originally Posted by livid_wrx View Post
    That's a odd green.
    haha thanks for the feedback. i call it cactus.
  5. #4
    Mar 2014
    South East Michigan
    Any time
  6. #5
    Jan 2015
    strong island
    i know im supposed to cap the nipple of intake manifold but cannot find the purge valve for the life of me. its kind of looks like bpv right? i do not see that anywhere near the left of my alternator.
  7. #6
    Post a pic of your engine bay from a bit further out
    Resident Tuner @ WTF Tuning
  8. #7
    Jan 2015
    strong island
    here you go. hope its far back enough. Click image for larger version.
  9. #8
    Jan 2015
    strong island
    Quote Originally Posted by unseen View Post
    i think i figured some of it out.
    the second red circle is connected to the purge solenoid found at the second small blue circle. so i'll undo that connection and plug it at the intake/turbo inlet. this one im most certain of.
    the first red circle is less concrete to me, but i believe this leads to the pcv right in front under the intake manifold. i will also plug this at the intake/turbo inlet.
    the last, rightmost red circle i believe is to the crankcase breather which runs under and then parallel to the intake manifold on the backside. now i do not know how to gain access to this. there is a clamp on it, but it seems rather cramped underneath the purge solenoid. if anyone knows how to get it disconnected, please let me know.
    also, if anyone can confirm this is all correct, thatd be great. thanks for your time guys.
