Boost leak
Results 1 to 2 of 2
This is a discussion on Boost leak within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a leak on my 2011 wrx and I think it's from the bov vac hose. The hose the ...
    Nov 2014
    Land o' Lakes, Florida, United States
    Boost leak
    I have a leak on my 2011 wrx and I think it's from the bov vac hose. The hose the goes on top of the bov runs to something but on my car at the end of hose it's just dangling and I need to know where to put it back on at
    Aug 2012
    Tucson, AZ
    Quote Originally Posted by Daltonp45 View Post
    There's two hoses. The smaller one that comes off the nipple on the vavle? Or the bigger one? Also at what end is it dangling? On the vavle side or to where it should connect?
    The smaller line runs from the nipple on the valve to the backside of the engine. There's another nipple under the intake manifold in the center where the pcv valve is. You'll have to take the intercooler off and you should see it
    The bigger one goes into the turbo inlet. If that's off, you're going to have to get creative to get it back on. it connects to the turbo inlet directly under the intake manifold
    Pics would help as well for things like this for future reference.
    Might as well check the gasket and see if there's any blow by around the valve and intercooler
    You'll also want to replace the throttle body to intercooler hose with a silicone one as the stock ones fail
    Stinkeye member 520
