02 wrx oil temp overheat Neeed help!
Results 1 to 7 of 7
This is a discussion on 02 wrx oil temp overheat Neeed help! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So i was driving about 80 using the cruise control. Then i notice that my oil temp was getting hot,the ...
    Jan 2015
    So i was driving about 80 using the cruise control. Then i notice that my oil temp was getting hot,the i realized i was running little under 5 boost while on cruise control.Mean while my other temp gauge was good.Next thing i know i start to lose power so i down shift their was little clunk, did not smoke or leak any fluids. (only oil in the oil) Will start back up their was some squealing an clunking by the turbo an inter-cooler.I shut it down right away.Where to start what do you think my problems are?
    How high was the oil temp?
    What units is the "5" above?
    Are there external leaks or smoke?
    Man is a brute.... If you're cruel to him, he respects and fears you. If you're kind to him, he plucks your eyes out. Alexis Zorbas
    I lied. I cheated. I bribed men to cover the crimes of other men. I am an accessory to murder. But the most damning thing of all... I think I can live with it. And if I had to do it all over again - I would. Benjamin Sisko
    Jan 2015
    heated up to maybe 280. yes i believe that would be 5 above.And there was no smoke or leaks..i checked the oil to seemed to have only oil in it.
  5. #4
    Aug 2012
    Tucson, AZ
    Quote Originally Posted by brandys 55 View Post
    No is it 5 psi or what. What are the increments
    Stinkeye member 520
  6. #5
    Sorry I'm misunderstanding.
    5 what? PSI?
    280 what? Degrees Fahrenheit?
  7. #6
    Jan 2015
    Yes i do believe it would be 5 psi an 280 degrees Fahrenheit.whatever it would be on stock wrx..
  8. #7
    280'F is nearly 140C. I'd not expect to see that except under severe prolonged high rpm use on a track.
    Suspect significant friction internally, particularly if your oil pressure is low: bearings come to mind. Exclude the worst by starting with a compression test but I'd fear a big end issue etc.
