engine rebuild help
Results 1 to 15 of 16
This is a discussion on engine rebuild help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi guys I'm new to the forum. I just bought my first subaru. I'm looking to rebuild the motor or ...
    Dec 2014
    engine rebuild help
    Hi guys I'm new to the forum. I just bought my first subaru. I'm looking to rebuild the motor or have it rebuilt. Is there any good engine rebuild kits out there? How difficult is it to rebuild a subaru motor. It's an 04 wrx with the 2.0
    Palmyra, NJ
    Welcome.
    Your question unfortunately is a little vague and is too subjective.
    We don't know your level of competence or technical abilities. I've been around Subarus for years and I doubt I could rebuild an engine...
    What do you want your end goal to be? Just getting back on the road or do you want more power? What do you want the car to do? Also, why does it need a rebuild?
    2012 Lightning Red WRX Sedan
    ProcessWest TMIC Cobb SF Intake w/airbox Invidia Catless Downpipe Invidia Q300 Catback Kartboy Short Shifter
    OpenSource tuned by: Matty @ WTF Tuning
    Dec 2014
    I want it rebuilt. That's all I can tell you. At least stock or a little better. I'm not worried about it being super fast. I want to rebuild it because it has 200k on it. Well maintained but you can feel that it's underpowered even for stock. Still runs amazing but I just want it back to where it should be. How much would I be looking at spending on a rebuild and would it be better to rebuild it or just buy a motor and put it in?
  5. #4
    The Guy On The Couch TownLine500's Avatar
    Oct 2013
    Boston
    Welcome!
    Keep in mind a built engine will never last as long as a factory engine.
    Cost will be based on your builds direction.
    Labor will be pricy, do you know a reputable shop to do the build for you?
    You would probably do better with a replacement engine that came out of a wrecked WRX.
    Your question is still a little vague, the more specific you can be.
    The better we will be able to help.
    STINK EYE MOB #500
    2009 Subaru Impreza (I bought it new for my Mom)
    2004 Subaru WRX (Sold)
    2013 Subaru WRX Premium
    1996 Honda Civic Lx
    WRX genuine Face Ripping ACCELERATION!!!
    My Boston Beat Down Build Thread
    http://www.clubwrx.net/forums/builds...wrx-build.html
  6. #5
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by dlewis1000 View Post
    Just buy a factory shortblock and have the heads rebuilt as well as a port/polish job for a little more power.
    2002 FORESTER S
    1998 FORESTER S
  7. #6
    OMG WTF MainFrame's Avatar
    Texas, United States
    ^this.. it will be more reliable, and likely cheaper than a "rebuilt" engine.
  8. #7
    Palmyra, NJ
    I'd start with a Compression test on the current motor. Find out if your motor is healthy.
    Why spend money on it if the numbers come back within spec? Otherwise just do some maintenance: oil change, tranny fluid change, diff fluid change, maybe change some bushings/mounts, plugs, new filter, etc.
    Then drive it til the wheels fall off.
  9. #8
    engine rebuild help
    If it's still running in a way that -- direct quote -- is "amazing" I'd leave it alone because any of the solutions will cost 50% of the value of the entire car, and end up with any luck giving you a motor that runs, well, amazing.
    If there were nothing else in the works to spend money on at all and I had to do something I'd do what Donkey said, buy a block, send off the heads, do the timing and pump, full gasket set, add a clutch set, all hoses, and a map. It could give another 200K but it'd probably end up costing 5K.
    Man is a brute.... If you're cruel to him, he respects and fears you. If you're kind to him, he plucks your eyes out. Alexis Zorbas
    I lied. I cheated. I bribed men to cover the crimes of other men. I am an accessory to murder. But the most damning thing of all... I think I can live with it. And if I had to do it all over again - I would. Benjamin Sisko
  10. #9
    Dec 2014
    Well it feels underpowered even for being stock.
  11. #10
    Palmyra, NJ
    Being that this is your first Subaru, do you have any stock Subaru that you've driven to compare that to?
  12. #11
    zax
    zax is offline
    \_(ツ)_/ zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Uh, what?
    This could be many things. If you think the car has a bad motor, compression and leakdown test. If that comes back bad, THEN consider a rebuild. Pretty silly to rebuild something that isn't broken, especially when it will exceed the cost of the car.
    Zax's utterly unimaginably stock 2015 STi build thread
    Zax's Shaggin' Wagon Build Thread Now tuned for 99% pure Unicorn Jizz!
    Rollin' with the Bugeye Mafia #302 | N.E.R.D. Subject Zero
    Facebook me here
  13. #12
    Registered User WrxNate's Avatar
    Aug 2013
    Milwaukee,WI
    +1 to this. Does it just feel underpowered for what you mind thinks it should be? Maybe just have it tuned to run a more aggressive map first.
    Uh, what?
    +1 to this too. Find out what's actually wrong (if anything) with the motor before thinking about rebuilding it. Pointless to spend the money fixing something that's not broken or overfixing something.
    Nate | Stink Eye Mob #023
    2014 WRB WRX Hatch
  14. #13
    Palmyra, NJ
    Quote Originally Posted by WrxNate View Post
    Exactly!
    Perhaps it is underperforming...but that could be as simple as a torn turbo inlet or something that will cost $100 to fix as opposed to $4000.
  15. #14
    Dec 2014
    Even with 200k on the motor? I want it to be a dd but I want to start making it more powerful. Could I still do that on the block with 200k?
  16. #15
    If it ain't broke, don't fix it.
