2002 WRX Wagon cranks, fires and immediately stalls.
Results 1 to 7 of 7
This is a discussion on 2002 WRX Wagon cranks, fires and immediately stalls. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; New guy here with a puzzling issue. First let me say I am new to Sybarus but not automotive in ...
    Dec 2014
    New guy here with a puzzling issue. First let me say I am new to Sybarus but not automotive in general. This problem has me absolutely stumped. This 02 Subaru 2.0l Turbo turns over just fine, it starts to run but stalls almost immediately. Today I installed new plugs, new fuel filter, new air filter, charged the battery, put in 5gallons fresh gas and seafoam.
    I have tried disconnecting the MAF, the IAC, and TPS. But still the same result. I hooked up the scanner and I don't have any codes. I towed it behind the truck and pulled it around the lot let the clutch out and she fired right up but as soon as I put the clutch in it stalled and died but if I left the clutch out again she came back to life. During the time it was running behind the the truck if you attempted to give it any throttle it would just sputter and pop and want to die. When I attach a fuel pressure gauge inline with the filter and fuel rail I get 43psi with KOEO. I can't remember what the reading was under cranking. I will re test and report.
    The car has a JDM replacement engine and computer. It ran perfect when it was parked about 3mos ago. Any help is greatly appreciated
    Dec 2014
    Just realized I forgot mileage and mods.
    Mileage 141,605
    Mods:
    blitz ID boost controller
    Blitz ID power meter
    Blitz turbo timer
    Blitz BOV
    Catback exhaust (unsure of make)
    Short shifter
    Perrin crank pulley
    Samco silicone boots
    OMG WTF MainFrame's Avatar
    Texas, United States
    I assume you reset the ECU when you tried starting it with the MAF unplugged?
    If it was just sitting, then I would look over the electrical real good, especially looking for bad/dirty grounds.. I suppose it could be a bad crank or cam position sensor. It's hard to say really.. not a lot to go off of.
  5. #4
    Dec 2014
    Yes I reset the ECU after I tested with the sensors unplugged.
  6. #5
    Moderator Donkey's Avatar
    Da boonies,Va
    Test the fuel pressure. Check the cam and crank sensor connections. Hopefully no mice used it as a playground. Kinda sounds like it jumped timing for some reason.
    2002 FORESTER S
    1998 FORESTER S
  7. #6
    Dec 2014
    I have tested fuel pressure KOEO and the pump puts out 43psi to the fuel rail. I will retest today as I forgot the reading under cranking. I also picked up a Walbro 255 that I will be installing.
    I have also checked Cam position sensor and it's good I haven't had a chance to pull the timing cover just yet to check the CKP or timing gear teeth.
  8. #7
    Dec 2014
    Update: I installed the new Walbro pump today. I have 50psi fuel pressure to the rail under cranking and when the pump is primed turning the key on. I also checked the grounds to the engine, body and battery. All were cleaned very throughly and reinstalled nice and tight. I checked and cleaned the Cam and crank sensors. I wasn't able to back probe them with the scope because I was unable to find the leads. I popped off the side timing covers and nothing was out of the ordinary. I pulled the coils and I am getting spark under cranking.
    The next thing I am going to do is swap in some can and crank sensors from a motor in the shop to see what happens. I am also thinking about locating another ECM just to see if that makes any difference.
