(Double Check) Using DEXRON III ATF for "Power Steering"
Results 1 to 2 of 2
This is a discussion on (Double Check) Using DEXRON III ATF for "Power Steering" within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Power Steering Fluid Type: DEXRON III Capacity: 0.7 quarts Is this true before i do it? Why wouldnt i just ...
    Registered User jcerillo70's Avatar
    Jun 2014
    West Freehold, New Jersey, United States
    Type: DEXRON III
    Is this true before i do it? Why wouldnt i just use regular power steering fluid like : http://www.pepboys.com/product/detai...power_steering
    I have a 2013 WRX,
    (Joe Cerillo)
    2013 WRX Hatch (WR Blue)
    -SPT Exhaust -AEM Intake-cobb Down Pipe-Cobb V3-1000 cc injectors-upgraded Fuel pump-Process West intercooler
    -Grimm Speed Light weight pulley-Pro Tune
    The factory manual for my 2002 WRX also states 0,7l of Dexron III. This means the fluid must meet General Motors specifications GM Spec GM6417M, GMN10055. General Motors developed the fluid and the specs.
    There are no specifications listed for the product you linked. I can't tell if it's a Dexron III fluid (it would either say Dexron III or General Motors Spec GM6417M, GMN10055 on the bottle). This is good news though, because if there is any doubt, then there is no doubt. I'd not use it.
    I'd find the correct fluid and use only that, exclusively.
    Incidentally, there is no stated service interval for the power steering fluid. My car still has the original fluid from 2002. Unless you have a leak, you're just doing preventative maintenance I suppose. If it's preventative, you have time to get the correct fluid. If you're fixing a leak, you're shopping for parts anyway so you may as well get the correct fluid. Either way...
    Man is a brute.... If you're cruel to him, he respects and fears you. If you're kind to him, he plucks your eyes out. Alexis Zorbas
    I lied. I cheated. I bribed men to cover the crimes of other men. I am an accessory to murder. But the most damning thing of all... I think I can live with it. And if I had to do it all over again - I would. Benjamin Sisko
