Help! Terrible engine noise
Results 1 to 8 of 8
This is a discussion on Help! Terrible engine noise within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So my car stopped running one day and I thought it was bad compression. Pulled the motor and did head ...
    Oct 2014
    Boston MA, Rochester NY
    So my car stopped running one day and I thought it was bad compression. Pulled the motor and did head gaskets. Started the engine and it's making the same terrible noise that it made right before it stopped running. Video of the noise is below. Please help!
    http://youtu.be/Tz2ssfYRquwe
    The Guy On The Couch TownLine500's Avatar
    Oct 2013
    Boston
    The video doesn't work.
    Does it sound like a rod knocking?
    STINK EYE MOB #500
    2009 Subaru Impreza (I bought it new for my Mom)
    2004 Subaru WRX (Sold)
    2013 Subaru WRX Premium
    1996 Honda Civic Lx
    WRX genuine Face Ripping ACCELERATION!!!
    My Boston Beat Down Build Thread
    http://www.clubwrx.net/forums/builds...wrx-build.html
    Registered User WRX-maniac's Avatar
    Sep 2013
    Western Maryland
    Def sounds like rod knock/piston slap to me
    2011 WRB WRX hatchback---Stage 2
    Stink-Eye Mob #301
    http://www.clubwrx.net/forums/builds...ld-thread.html <----Build Thread
  5. #4
    Oct 2014
    When i had the heads done at a local machine shop, they thought the valves were all good, and it made the same noise before.there wasn't any visible internal damage either. If timing was off that bad would it even run?
  6. #5
    May 2014
    Iowa
    That is nearly the same sound my 02 Outback made and it turned out to be the timing belt.
  7. #6
    Oct 2014
    Did you just replace the timing belt and the noise went away? Or did you have internal damage since they're interference motors?
  8. #7
    May 2014
    Iowa
    It had been making that noise for a few weeks until I figure out what it was. I was scheduled to have the belt changed and two days before the engine quit on the way home. Every valve was bent. I don't think they were bent until the motor stopped running.
  9. #8
    Aug 2012
    Tucson, AZ
    If the timing is off by just a few teeth they'll bend. They're very close
    Stinkeye member 520
