Super Clean and power washing cylinder heads?
Results 1 to 4 of 4
This is a discussion on Super Clean and power washing cylinder heads? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; As the topic says, I've got to re do some 03' WRX head gaskets and want to clean the heads ...
    Sep 2012
    N. Idaho
    As the topic says, I've got to re do some 03' WRX head gaskets and want to clean the heads up as best as I can before they visit the machine shop. I've looked around quite a bit on the internet. "Subaru Mike" seems to use super clean de-greaser and a power washer to cleaning heads. Is this safe, logical, ill-advised, etc? Cams and buckets will be out of course.
    Please chime in thanks.
    Moderator Donkey's Avatar
    Da boonies
    Should work. I have used siding cleaner from Home Depot as it is pretty safe for aluminum. I just soak the heads in plastic tote with a gallon of the cleaner and water.
    2002 FORESTER S
    1998 FORESTER S
    Sep 2012
    N. Idaho
    I was told to use super clean since its allot less harsh vs. something like simple green, but I don't even like s.g. that much either. That stuff is bad news if its left on ANYTHING. I'll power wash and air compressor dry the crap out of it then.
    thanks bud
  5. #4
    Da boonies
    Simple Green does has multiple formulas now. One being aluminium compatible. I think it is the "purple" label auto formula.
    2002 FORESTER S
    1998 FORESTER S
