Something doesn't seem right..
Results 1 to 12 of 12
This is a discussion on Something doesn't seem right.. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So I recently bought an '04 WRX, all stock with 85k miles. First off, I've never owned a turbo car ...
    Oct 2014
    So I recently bought an '04 WRX, all stock with 85k miles. First off, I've never owned a turbo car myself, I've driven a few STIs and a few other boosted cars, but this is my first personal ride. Anyway, I'm curious if my car is spooling properly of if I have a boost issue.. it just feels like my boost falls off sooner than it should and doesn't spool enough in certain gears such as 2nd. Am I just not used to having a turbo, meaning this is normal for these cars, or is there anything I should be concerned with and need to start checking things? The highest numbers I've seen is 7lbs at 5000rpm in 3rd gear..
    That's waste gate pressure. Something sounds wrong.
    Man is a brute.... If you're cruel to him, he respects and fears you. If you're kind to him, he plucks your eyes out. Alexis Zorbas
    I lied. I cheated. I bribed men to cover the crimes of other men. I am an accessory to murder. But the most damning thing of all... I think I can live with it. And if I had to do it all over again - I would. Benjamin Sisko
    zax
    zax is offline
    \_(ツ)_/ zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Yep. My bet is the ECU has pulled boost.
    Zax's utterly unimaginably stock 2015 STi build thread
    Zax's Shaggin' Wagon Build Thread Now tuned for 99% pure Unicorn Jizz!
    Rollin' with the Bugeye Mafia #302 | N.E.R.D. Subject Zero
    Facebook me here
  5. #4
    Oct 2014
    So what would be my best plan of action?
  6. #5
    zax
    zax is offline
    Nov 2008
    Take it to someone who can troubleshoot the problem. These things are usually due to:
    1. Incorrect fuel/timing map for modifications
    2. Failure to use Premium fuel
    3. Gross vacuum leak
    4. Failure of primary sensors or knock sensor
    5. Dirty MAF or incorrect O2 sensor
    You say the car is unmodified. Are you certain? Are you sure the ECU has not been reflashed with an improper map?
    Facebook me here
  7. #6
    Aug 2012
    Tucson, AZ
    To add in the car may now be unmodified but was at one point with the old map still flashed
    Stinkeye member 520
  8. #7
    Oct 2011
    Santa Ana, CA
    I'd check the boost control lines for cracks. At that age I wouldn't be surprised.
  9. #8
    zax
    zax is offline
    Nov 2008
    Ah true. Or a missing restrictor pill
    Facebook me here
  10. #9
    Oct 2014
    I can't speak for the previous owner but I only use 93 octane fuel and I actually just cleaned the MAF so those 2 are out, but it sounds like I need to take it to someone who can check the map and the boost control lines . Thanks guys.
  11. #10
    Oct 2005
    Late Devonian
    My bet: Vac lines or BCS.
  12. #11
    Oct 2014
    I talked to a buddy that works on turbos and actually used to own a bug eye WRX and he thinks it may be vacuum related also. Just curious but what kind of boost numbers should I be expecting out of a stock setup?
  13. #12
    Oct 2005
    Late Devonian
    Quote Originally Posted by mikestripes View Post
    12-14 psi.
    These are the lines that matter. Check the line with the restrictor pill (feel for one) as well. Otherwise the boost control solenoid usually sticks closed.
