power loss "surge" type feeling
Results 1 to 5 of 5
This is a discussion on power loss "surge" type feeling within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; so recently I was having problems with a busted y pipe and cracked vacuum lines replaced both but when I ...
    Registered User drumbeat's Avatar
    Aug 2014
    so recently I was having problems with a busted y pipe and cracked vacuum lines replaced both but when I open up the throttle right after the shift to third it lags out for a second and check engine light sparks on what would cause this?
    Aug 2014
    after tweaking my Nov seems to be running fairly smooth but it still gives me hell if I try to get the gas pedal past 3/4 way down
    Aug 2014
    Quote Originally Posted by drumbeat View Post
    after tweaking my bov seems to be running fairly smooth but it still gives me hell if I try to get the gas pedal past 3/4 way down
  5. #4
    Aug 2014
    finally got a good readout wastegate solenoid is done for
  6. #5
    Aug 2014
    well got a p0244 code not actually sure if the problem is boost controller or wastegate
