Low Idle problem!?!
Results 1 to 5 of 5
This is a discussion on Low Idle problem!?! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; 2004 wrx Sounds normal when revved up but it's idling super low and it sounds like it's going to die. ...
    Aug 2014
    Caldwell, Idaho, United States
    Low Idle problem!?!
    2004 wrx Sounds normal when revved up but it's idling super low and it sounds like it's going to die. The engine is shaking a lot What contibutes to this problem so I know what to check.
    OMG WTF MainFrame's Avatar
    Texas, United States
    What mods and mileage? How low is super low? Do you have a way to check your fuel trims in Learning View?
    I would check for any post MAF leaks (learning view could help with this). If you determine there are no leaks, I would try cleaning the MAF, and probably the throttle body and idle air control valve.. the throttle body tends to get gunked up after about 100k miles.
    Aug 2014
    No mods. 160k mileage. So I'll check the MAF for leaks thank you.
  5. #4
    You could also try resetting the ECU, and/or unplugging the front O2 sensor to try and help diagnosing the issue. Also, look over all the wiring in the engine bay (especially where ground wires are mounted). Dirty/bad grounds can cause all kinds of screwy things to happen.
  6. #5
    Aug 2012
    Tucson, AZ
    Can clean throttle body out, look everywhere for vacuum leaks too
    Stinkeye member 520
