My 04 WRX has been idling low and i cant figure out why.
Results 1 to 6 of 6
This is a discussion on My 04 WRX has been idling low and i cant figure out why. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I usually idle at about 750/700 ish and now for the oast few days ive been idling at about 500/550. ...
    Aug 2014
    I usually idle at about 750/700 ish and now for the oast few days ive been idling at about 500/550. I checked my engine for a vaccum leak, and i dont appear to have one. I also just cleaned my air filter, and am not getting any codes for an o2 sensor messing up so im not sure what could be causing it. The car runs perfectly normal, its just that idle. When i start the car when the engines cold i get a normal start up, and the car idles at around 1k ish and slowly goes down to the 500. If i start it with a semi warm engine, ill get almost a weaker start, where the idles will shoot up to 1500 then almost instantly dip down to 500. What could be causing this issue?
    Registered User tirerob's Avatar
    Nov 2012
    bug-eyeing in the Bakken
    i almost think that on the manual wrx 500/550 is the correct idle rpm.
    id double check the service manual, but after a minute or two thats where my car settles to.
    when my friends come up, i hear, "you sold the camarrrroooh.....HOLY BLEEP A WRX!"
    Ya has that effect on me too.
    Rob
    Where did he go?? http://www.clubwrx.net/forums/builds...ll-thread.html
    The 02 tach cannot measure 500 rpm. That's where the needle rests.
    Nov 2012
    Oops. Thanks SD. I was just out looking to(curious). And I'm around 700 ish. Might be because its nearly 45° but that's where I'm idling warm. Shows how much I pay attention to the tach lol.
    Rob
    Moderator Donkey's Avatar
    Da boonies,Va
    Try cleaning the IAC valve on the throttlebody. Google should bring up several tutorials on cleaning the 02-05 USDM WRX IAC valves.
    2002 FORESTER S
    1998 FORESTER S
    Registered User Snear121's Avatar
    Aug 2014
    Hello. I know that to get subaru s into the uk they made an intelligent charging system with the alternator so they pass emissions. If you have everything off the alternator only dishes out 12 volts and the revs go low or weaker too. If you put the heater fans on minimum or put side lights on you get the full 14.2 volts and engine idles much better.
