2002 Wrx Heater Blower Fan not working on any setting 1-4
Results 1 to 7 of 7
This is a discussion on 2002 Wrx Heater Blower Fan not working on any setting 1-4 within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have read through countless threads on Heater Blower Fans and resistors and i feel like i have a pretty ...
    Aug 2014
    I have read through countless threads on Heater Blower Fans and resistors and i feel like i have a pretty good understanding of how it all works. My major question is when i turn my knob to 1 2 3 or 4 nothing happens and ALSO if the A/C Button is depressed it never lights up green like it is should. I already went and purchased a used fan transistor setup and i am ready to swap them out but my worry is my problem lies in the blower motor relay tucked up behind the fuse panel to the left of the steering wheel. Is the fact that the Green light on the A/C button not lighting up a tell tale sign that it is that relay and not the actual blower motor?
    Palmyra, NJ
    If the light doesn't light up, I'd think that the control panel itself isn't getting power. So that could be a fuse, relay, or the panel itself. With that, I don't think it'd be the blower motor.
    Aug 2014
    if i push the defrost button just to the right of it illuminates orange just like it should
    Aug 2014
    i have my glovebox off and the old heater motor almost unbolted...got the two lower (easy bolts) off now im just trying to access the top one that is kinda PITA...im just gonna swap them out for the hell of it and see if it fixes it...im guessing its gonna still be doing the same thing...i will keep you posted after i get this other one installed back in and hooked up.
    Aug 2012
    Tucson, AZ
    Before doing anything more laborious, make sure the heater switch didn't die on you and even easier check the fuses
    Hawkeye Alliance 520
    Previous cars:
    2010 Mitsubishi Lancer (sold)
    2009 WRX (sold )
    2013 Scion tC (sold)
    2008 Audi A4 (Totaled)
    Photographer/storm chaser
    https://www.facebook.com/kevinrimphoto
    IG - kevinrimcoski
    May 2017
    I'm having the same problem now. What was the fix?
    May 2017
    Fuse 17 was blown. Even though both blower motor fuses 1 & 2 were fine, fuse 17 also feeds the blower motor relay - did not know that until I found the wiring section of the Subaru service manual on-line.
