Cobb filter fell off without knowing
Results 1 to 8 of 8
This is a discussion on Cobb filter fell off without knowing within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey guys I have a question for my friends car. He has a 2011 sti and he just noticed that ...
    Registered User jsantos1082's Avatar
    Aug 2012
    River Edge, NJ
    Hey guys I have a question for my friends car. He has a 2011 sti and he just noticed that his cobb air filter came off. He has been driving the car without it. He has the box so it was hard to notice it. What kind of damage can that do to the engine?
    JOE
    2013 WRX DGM
    Stink Eye Mob #82
    Quote Originally Posted by jsantos1082 View Post
    The role of a filter is to filter air so that no particulate matter enters the engine. The role of a filter is not to maximize flow, yet many imitation filter makers emphasize that and don't explain how it's possible without allowing more dirt in at the same time. Anyway: Dirt increases wear. Dirt is never good in a motor.
    If the car is not tuned for the Cobb intake, I'd consider switching back to the authentic Subaru intake. I've yet to see anyone, anywhere, show reproducible data proving an aftermarket intake filters air better than the Subaru intake. (Data in this case means statistically significant used oil analyses showing decreased levels of particulates, wear metals, and silicone). Nobody has shown this.
    If the car is tuned for the Cobb intake, replace the air filter. Clean the MAF, replace the oil and oil filter, and go about life. What's done is done.
    Aug 2012
    River Edge, NJ
    Yeah he is tuned for it with the AP. Thanks!
    JOE
    2013 WRX DGM
    Stink Eye Mob #82
    Registered User subypete's Avatar
    Jan 2008
    Forsyth, IL
    Running without a filter is never a good idea... fairly obvious statement. Whether or not you friend has damaged his engine depends on several factors:
    - The duration of time the car was run without a filter
    - The cleanliness of the air
    - Whether the MAF readings got messed up due to the new airflow path
    As long as the car was not run for a significant amount of time, in a dirty environment (dusty roads, construction, etc.) they might be OK. If otherwise, there might be scoring to the cylinder walls which could lead to serious issues down the road.
    Additionally, if the lack of a filter caused the airflow to significantly deviate from what the car was tuned for, the MAF readings could be all over the place causing rich/lean conditions. In that case, the car would likely have felt a little off... rough idle, loss of power, etc.
    That being said, like SD_GR said, what's done is done.
    2013 Nissan Leaf SL - Extra Leafy
    2002 OBP WRX - Stage II - "Black Betty" - SOLD
    1987 Subaru GL Wagon - Stock - "Mr. Ratburn" - SOLD
    Registered User Infamouszoltan's Avatar
    Jun 2014
    Salt Lake City, UT
    When did we stop being who we want to be, and start being the person the world told us to be...
    Stink Eye Mob #801
    Instagram: Infamouszoltan
    InfamousZoltanSTi
    OK then replace, clean, change oil etc. If you are curious and have $50 burning a hole in your pocket you might send off a sample of the used oil for analysis. The metals and silicone should be through the roof. (In fact if you do this, tell them what happened so they have some sort of context to explain the bizarre data they'll be collecting).
    Palmyra, NJ
    It gon blow'd up.
    Or not. It will be fine. The amount of particulates entering in the box won't be that much. If you're worried, heed the other advice in here.
    Aug 2012
    River Edge, NJ
    My friend is nervous, but I told him what's done is done. Thanks for your replies guys!
    JOE
    2013 WRX DGM
    Stink Eye Mob #82
