09 Wrx running on 3 cylinders, compression is fine. What next?
Results 1 to 7 of 7
This is a discussion on 09 Wrx running on 3 cylinders, compression is fine. What next? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I am having a bit of difficulty figuring out what is plaguing my car. I am running a 20g swapped ...
    Registered User Ashesofthewake's Avatar
    Oct 2009
    CNJ
    Question 09 Wrx running on 3 cylinders, compression is fine. What next?
    I am having a bit of difficulty figuring out what is plaguing my car. I am running a 20g swapped 09 WRX with full bolt ons and pushing 331hp/351tq at the wheels. Stock internals. The other day on my way to work the car started running rough intermittently. (low power, strong vibrations etc) It would happen for about 5 seconds then go away completely. I finally pulled over and got a tow home when it started running rough continuously. There was no CEL, however the roughness counter on cylinder 3 was counting rapidly up to 100 over and over again. Raw fuel smell from exhaust as well.
    The first thing I tried was swapping the coil packs to no effect. Car was still not really running on cylinder 3.
    I tested compression on cylinder 3 only and got 127 psi
    The plug looked fine, nice golden brown and and I tested the spark with the plug out of the car and it appeared strong.
    I am a little stumped. Cylinder 3 obviously seems to be getting fuel as I can smell raw fuel in the exhaust, and my coil packs are fine and there is a strong spark. Any ideas what I should look at next?
    It may not be getting all that at once I guess. I'd be tempted to swap injectors. If the problem doesn't move to another cyl I'd suspect wiring.
    Oct 2011
    Santa Ana, CA
    Do another compression test, and with the rest of the cylinders as well. What are they getting?
    Then do a leakdown test.
    My car did that almost exactly when I had a slightly burnt valve causing bad compression.
    Moderator Donkey's Avatar
    Da boonies,Va
    2002 FORESTER S
    1998 FORESTER S
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    127 PSI is low...
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    I'm betting the others will be similar and hoping compression is ok for the OP.
    Oct 2009
    CNJ
    Me too.
    I'll start by finishing the compression test. I know 127psi isn't optimal but the car does have 72K miles on it. In my head anyway I couldn't see 127psi causing it to not run at all on that cylinder, but I could be completely off base.
    If my numbers are all around that area I'll swap injectors and see if that makes a difference , but they are pretty new ID1000s.
    Thanks for the suggestions guys, if it turns out to be valves or piston related I suppose I have an engine build in my near future.
