Blowing up parts? 2002 wrx. ...bov?
Results 1 to 15 of 29
This is a discussion on Blowing up parts? 2002 wrx. ...bov? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So recently I was having lag issues when the boost would kick shortly after the boot between the intercooler and ...
    Registered User drumbeat's Avatar
    Aug 2014
    So recently I was having lag issues when the boost would kick shortly after the boot between the intercooler and turbo exploded so I got a new boot checked all my lines and did general maintenance during my test drive again lag and the part burst open my bov is also malfunctioning and she won't run any advice on how to repair ?
    Moderator Donkey's Avatar
    Da boonies,Va
    2002 FORESTER S
    1998 FORESTER S
    Aug 2014
    Sorry trying to use my crap phone to post and it's hard to be proper when typing takes you twenty minutes I just want my baby to run and the Subaru shop here didn't know what the problem was
    Registered User 02_Subie's Avatar
    Jun 2014
    SE Iowa
    You say your bov won't work, if the turbo isn't forcing air into the intercooler(you say the boot burst) then there wouldn't be any pressure to open the bov. Did you use hose clamps on your connections?
    Aug 2014
    Yeah made sure everything was tight and back the way it was supposed to this is my first turbo car and I have very little mechanical knowledge when it comes to them
    Aug 2014
    But I did everything the mechanic pointed out from the diag
    Aug 2014
    The way it blew up was like it had a massive load of pressure on it
    Jun 2014
    SE Iowa
    How many psi of boost are you running? What kind of blow off valve do you have?
    Aug 2014
    Roughly 12 and greddy rz
    Jun 2014
    SE Iowa
    I know a lot of people will tell you an oem bypass valve is your best bet. Blow off valves can cause the car to run rough, but if yours isn't opening or is stuck shut, it could be the cause of your problem.
    Aug 2014
    That's what I was thinking but wanted to get opinions from some experienced people
    Registered User tirerob's Avatar
    Nov 2012
    bug-eyeing in the Bakken
    was the car tuned for the aftermarket bpv?
    have you read the big BOV thread yet? it has more info than you can shake a book at. no really, it took me a day to read the hole thing. its huge. mostly, use a factory BPV or major tuning for the aftermarket ones.
    try swapping the stock or A stock bpv back on to it and using or reconnecting the factory re circulation hose to the turbo inlet hose? are your turbo's vacuum control hoses in the right place and the boost pill in the right hose? ummm...did you check for anything that could have plugged the intercooler on the inside(ok now im reaching but hey!) at 12 pounds of boost, the only thing you should be blowing up are speed limits. that is a nice safe boost level 2.5 psi below stock tuning levels. course, factory hoses....
    when my friends come up, i hear, "you sold the camarrrroooh.....HOLY BLEEP A WRX!"
    Ya has that effect on me too.
    Rob
    Where did he go?? http://www.clubwrx.net/forums/builds...ll-thread.html
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Take it to someone that understands the car. Sorry, but even if we could troubleshoot your problem, it sounds like you don't understand the car well enough to identify what to fix...
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Aug 2014
    Well seems I have a few ideas thanks guys if it still gives me trouble I'll take her to the shop. zax you have a good point but how will I learn if I never try.
    Aug 2014
    I got it six months ago with 225k miles and a really shady aftermarket setup
