Blowing up parts? 2002 wrx. ...bov? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
This is a discussion on Blowing up parts? 2002 wrx. ...bov? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by drumbeat how will I learn if I never try. You have a point, and I admire your ...
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by drumbeat View Post
    You have a point, and I admire your persistence. I wish you the best.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Registered User drumbeat's Avatar
    Aug 2014
    Removed the intercooler and Bov checked all lines seals and main components. what do I look for on the bov? Everything else looks great so if it's not bov I'm going for sensors
    Oct 2005
    Late Devonian
    First look for if it is a stock BPV. Since it isn't, by far the best thing to do is to get one and sell that for a profit.
    Otherwise, find the manufacturer's instructions on how to set the one you have properly and replace that gasket from the dealer. Be careful it is going in aluminum threads there IIRC and they will strip easily. It has to be adjusted correctly or you will have issues like that you describe - they aren't just put on and go. It looks like that model if it is "RS" can be set for recirc. which would be preferable and as good or better than stock in all regards. If they chose to plumb it like that, and got 225K out of the car, it makes me think it might not be so shady.
    Are you getting compressor surge? You can listen to it on youtube.
    Thanks for your interest in GReddy Products
    The top nipple on the top section will connect to your intake manifold (so it reads both vacuum and pressure and does not get bled off to anything) While the lower fitting is a vent for the internal diaphragm This one should be left open and not connected to anything.
    Make sure when you adjust the stiffness of the valve that you first loosen the lock nut before you adjust the set screw. Adjustment will very from car to car, so you need to use trail and error. Generally you want to valve as tight as possible, without getting any compressor surge. You don't want it too loose or it can open too early and you will loose boost. The valve should make one clean blowing sound, it should not stutter. It should also not open before the throttle is shut.
    http://www.greddy.com/upload/file/11599501_bi.pdf
    What else do you know about the setup on the car. If very little, pictures of various components would help. Does it have an MBC?
  6. #19
    Aug 2014
  7. #20
    Registered User tirerob's Avatar
    Nov 2012
    bug-eyeing in the Bakken
    Wow. That very factory timc hose looks like my brothers. Picked up a lot of boost after it was fixed haha
    when my friends come up, i hear, "you sold the camarrrroooh.....HOLY BLEEP A WRX!"
    Ya has that effect on me too.
    Rob
    Where did he go?? http://www.clubwrx.net/forums/builds...ll-thread.html
  8. #21
    Aug 2014
    Right now all my leaks are being sealed with thermal tape till the first whoever owned it before me haphazardly upgraded a few things but didn't go all the way 18g turbo for some reason a front mount oil cooler crappy unclamped hoses very sloppy and being my first tuner (always had classic American muscle before) it has me a little confused but I'm figuring it out
  9. #22
    Aug 2014
    Would love to get a hold of a service manual
  10. #23
    Nov 2012
    Understand that. I had been driving a overly modified camaro as my only car for 17 years. I can still pick jets out of my tackle box of extra parts to tune a edelbrock carb mostly with just my ear and a vacuum gauge/timing light. There are service manuals online free for download. I can't remember the sight but maybe one of the veteran members or mods have a link. I can look it up in a bit when I get to my laptop...I can't link on mah phone lol
    Rob
  11. #24
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    I got it six months ago with 225k miles and a really shady aftermarket setup
    Here are the manuals though. Good luck! http://ken-gilbert.com/impreza-manuals
    2007 Outback 3.0R wagon
  12. #25
    Aug 2014
    wastegate solenoid is bad need to find one after replacing the y pipe and vacuum lines it led me to the wastegate hoping problems end there
  13. #26
    Registered User SubaruWRXJosh's Avatar
    Jul 2014
    MA
    I know you have taken the BOV off and checked it, but have you tried putting the bypass valve on and driving it like that? All the advice I can give you is to keep the BOV off the car and put the bypass valve on and try driving the car like that. Nothing good (performance wise) can come from a BOV. I do want a BOV, but will never get one because of the issues. The 2002 WRX's are very sensative and I especially wouldn't put one on your car. Hope everything works out well.
    2013 Subaru WRX Premium
    Torqued Performance Stage 2, Invidia Catless Downpipe, Tomei Equal Length Headers, Cobb EBCS, Group N Motor Mounts, Perrin Transmission Mount, Perrin Pitch Stop Mount, Hood Scoop Fins, Kartboy Short Shifter, Kartboy Front & Rear Shifter Bushings, Perrin Heat Shield, STRi 52mm Amber Boost Gauge, SMY ClusterMaker Pod, Rally Armor Mud Flaps, Subaru OEM Black WRX Ornaments
  14. #27
    Aug 2014
    actually couldn't pick up the bpv still running with the bov which seems to be alright now that I tweaked it and replaced the y pipe with an aluminum setup and popped on some vacuum lines but now it's throwing a code for the turbo wastegate solenoid the boys down at the rally shop said could also be my stock boost controller but I dunno how to test that
  15. #28
    Moderator Donkey's Avatar
    Da boonies,Va
    What code was it?
    2002 FORESTER S
    1998 FORESTER S
  16. #29
    Aug 2014
    P0244
