2007 WRX overboosting?
Results 1 to 7 of 7
This is a discussion on 2007 WRX overboosting? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey everyone, so tonight I noticed that my boost spiked at 17.12 psi on my accessport when it should be ...
    Registered User DatsikWRX's Avatar
    Apr 2014
    Westchester, NY
    Hey everyone, so tonight I noticed that my boost spiked at 17.12 psi on my accessport when it should be at about 14. Ive noticed in the past 2 weeks that it has been going a little over 14. The car is cobb stage 1. I was recommended to run the cobb stage 1 low wastegate tune. Will this work or do I have a serious problem? Thanks!
    2007 WRX Wagon- Stage 3- Blouch 16g | CNT 38mm Up Pipe | Tial 38mm EWG | GS EBCS | ID1000CC | DW255 FP | Invidia N1 Race Catback | CNT Catted DP | STI TMIC | Cobb AP V3 | Cobb SF Intake | H&R coilovers | Rally Armor UR Mud Flaps | Cusco Sway Bars | SS ..... 317whp/317wtq @ 18psi
    1998 Trans Am WS6- MGW short shifter | long tubes | aero chamber catback | LS7 Clutch | other go fast parts
    1978 Camaro RS- 350 crate engine. One wheel burnouts FTW- sold
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    The LWG map may help.
    Sent from my Nexus 7 using Tapatalk
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Apr 2014
    Westchester, NY
    If it doesnt, do you know what could be wrong? Sorry if dumb question, still new to all this but trying to learn as much as possible
    zax
    zax is offline
    Nov 2008
    Take a datalog with the following parameters:
    - throttle percentage
    - calculated load
    - boost
    - wastegate duty cycle
    - rpm
    3rd gear pull to at least 5000 rpm. Post here.
    Facebook me here
    Oct 2005
    Late Devonian
    Zach will be able to help you more if you take that log. In general though any leaks between the turbo, boost control solenoid, and wastegate actuator will increase boost like that.
    Apr 2014
    Westchester, NY
    Ok so I was going to do a log today but the dumb a** new jersey gas attendent who put half a tank of 87 octane in instead of the 93 that I ASKED for put a stop to that.. also, I switched to the low wastegate stage 1 map and I did a pull before the gas incident and it hit 14.8 psi, then another at 14.3. I will put up a map as soon as I get a proper tank of 93
    Apr 2014
    Westchester, NY
    Ok so here is my log! Sorry it took so long to put up
    https://docs.google.com/spreadsheets...gid=1666964976
