wrx 2010 rad
Results 1 to 15 of 16
This is a discussion on wrx 2010 rad within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; just got back from dealership, they tell me it's a plugged rad... everheats, inside of the rad looks clean, can ...
    Jul 2014
    kelowna
    wrx 2010 rad
    just got back from dealership, they tell me it's a plugged rad... everheats, inside of the rad looks clean, can this be possible? tomorrow i guess ill put on water thru and see what comes out, test the thermostat... dealership had no rad no cap no thermostat, funny place..
    anyhow i was thinking of buying this thing : does this make sense?
    Replacement Radiator 2008 2010 FOR Impreza Manual Transmission 2 5 45119FG030 | eBay
    thanks
    Jul 2014
    kelowna
    Rad changed, thermostat, rad caps, had prestone tested for hydrocarbon, found nothibg so head gasket is ok had coolant system pressurized so that's OK too... Is it possible the turbo Is cracked and its pressurizing the coolant system???
    sent from nexus
    What were your initial symptoms?
    Jul 2014
    kelowna
    Coolant would come out into expansion vase slooooowly after 100km would start overheating. Took thermostat out rode 500km not a drop came out. Beat the living **** out of it no problem
    sent from nexus
    So then replacing the thermostat with a known good thermostat hasn't solved the issue?
    Jul 2014
    kelowna
    Nope nothing has changed
    sent from nexus
    Sorry I don't understand. You stated:
    So there's no problem?
    Jul 2014
    kelowna
    Yes! Still the same problem after everything I described I changed earlier!
    sent from nexus
    Try burping the system repeatedly.
    Jul 2014
    kelowna
    I did lol
    sent from nexus
    Aug 2012
    Tucson, AZ
    What was your procedure for burping. These cars have a very specific way
    Stinkeye member 520
    Jul 2014
    kelowna
    Jack up right front fill let iddle 20 min see fans start stop 5 6 times adding water when goes low pressing on the hoses to move air around
    sent from nexus
    Jul 2014
    kelowna
    Went to the dealer to tell them trouble shooting didnt turn out right, nothing changed after the 2 rad caps, thermostat and rad... Now there saying its the water pump
    sent from nexus
    Aug 2012
    Tucson, AZ
    Quote Originally Posted by paascal View Post
    sent from nexus
    Hell if they say it's the w/p and they're wrong I'd raise hell and make them fix whatever it is for free then at that point. What do you have to lose?
    They tell you why they say it's the water pump at all?
    Stinkeye member 520
    Jul 2014
    kelowna
    They already said they will pay rad if it'd not that... I was at the garage, for 2nd trouble shoot, car was running 104 celc at idle (never did this when rad was full). They revved it to 3krpm temp went down to 92, as soon as they let rpm drop it raised back to 100.. Lower rad hose was cold, would seem pump doesn't flow enough... I thought it could be the turbo that the water jacket it cracket and turbo boost in coolant system by they never saw this ever happening
    sent from nexus
