Okay so got the clutch in no problems everything hooked back up slight problem getting the tranny mounted but nothing major. When I went to start the car it started for about 2 seconds then cut off. Checked the code it was P2433. I had read that sometimes when pulling out the starter the sensor can pop off. So I pulled the intercooler and low and behold the sensor was off the secondary air system. Put it back on and put the intercooler back on and now it won't start it cranks just won't turn over, not sure why its doing it. Checked all sensors and have not seen anything pinched, unhooked, anything. The car is a stock 2006 wrx.
What I have tried:
Tried a different battery no go.
Tried a different starter no go.
Checked all fuses.
Checked all connections.
Positive cable is fine had a little corrosion at the top cleaned it off and stripped it down a ways no other corrosion.
No codes are tossing now so I am completely lost any help would be appreciated.
What I have tried:
Checked all fuses.
