new wrx 2010 wagon troubles...
Results 1 to 11 of 11
This is a discussion on new wrx 2010 wagon troubles... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hello, just bought this last week end, 200 000km. Drove fine from vancouver. next day motor got hot, without abusing ...
    Jul 2014
    kelowna
    hello,
    just bought this last week end, 200 000km. Drove fine from vancouver. next day motor got hot, without abusing it. needles just went high. let it coold down added water, next day drove for 300km, slowed down, same thing engine started to get hot... added water it,s ok again. cant smell prestone burning in the exhaust, can see it leaking. expansion vase gets filled up, i would be tempted to think it's only because it's overheating.
    i monitored the temp with a android torque app never saw the temps going up, im tempted to think it could be the thermostat that just lets the coolant get out of the expansion vase too early since the expansion vase fills up and i dont need to add much. maybe thermostat sticks closed sometimes?
    what do you guys think?
    car seems to be lagging a little between 4250 to 5000rpm, im guessing that its turbo related dont exactly know where to start on that one. anyone have an idea on how to troubleshoot?
    thanks for your help, im new to wrx!
    Jul 2014
    kelowna
    Anyone?
    sent from nexus
    Palmyra, NJ
    Start by burping the cooling system. You could have air in it, especially if you keep opening it up to add more fluid.
    Otherwise, it could very well be the thermostat faulting.
    Registered User Obeisance's Avatar
    Apr 2012
    not Ann Arbor
    If the thermostat is faulty, it should be obvious because the cabin heater should not blow hot, right?
    David - '05 WRX
    Jul 2014
    kelowna
    I think its more likely to be the rad cap, it leaks out in the expansion vase very slowly(400 km) and get hot when there isn't enough water in the cooling system
    sent from nexus
    Jul 2014
    kelowna
    hellooo, cut out the thermostat reinstalled it to see if it would cool enough. drove 400 km no issue, got a oem thermostat + rad cap (i could see white deposits on it thought it could be leaking)... reinstalled cap and thermostat, went fine for 150 km, same problem, the expansion vase fills up. ill try changing the main thermostat see what happens. anyone had a similar issue?
    Moderator Donkey's Avatar
    Da boonies,Va
    Head gasket possibly. I would get a coolant analysis.
    2002 FORESTER S
    1998 FORESTER S
    Jul 2014
    kelowna
    Done the said internal collapse of rad... And thermostat and rad cap... I have. a hard time understanding internal collapse, how can the rad collapse if its pressurized... Not to mention it runs fine without the thermostat no overheating whatso ever over 400 km!
    sent from nexus
    Da boonies,Va
    The radiator hose will collapse if the cap is defective. Had this happen to me. Once I popped the cap off the hose would expand back out.
    Sent from my magic banana...
    2002 FORESTER S
    1998 FORESTER S
    Jul 2014
    kelowna
    the tech said the radiator had collapse causing over heating... my question being how could a radiator collapse? it's pressurised i guess i should have asked him LOL
    dooooo, you said coolant analysis, soory i misread! i thought you said pressure test... to see if there are any hydrocarbons in the coolant? where do there get done?
    Da boonies,Va
    Most shops will do them now. I know NTB/Merchants/Tire Kingdom can do it along with oil analysis (engine/tranny/diff). It's a better test then looking for water in the engine oil as that doesn't always happen.
    2002 FORESTER S
    1998 FORESTER S
