A/C troubles
Results 1 to 5 of 5
This is a discussion on A/C troubles within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey guys i got a problem. Soooo... I took my 2008 Impreza to garage they changed my oil but said ...
    Aug 2009
    A/C troubles
    Hey guys i got a problem. Soooo... I took my 2008 Impreza to garage they changed my oil but said my A/C was busted. I didn't trust them but soon after I left I noticed my A/C would run cold then turn hot in less than 5 mins. So i went to another garage to get the A/C recharged (over a year later). They told me when they pumped my system I only had 13 grams of freon when i should have had 1lb in the system (my best guess is the first place pulled it out of my system as that during their "free inspection" i saw them messing with my low pressure line). After they filled the system they found no leaks so I know my freon is staying in my car.
    All that aside now my A/C blows cold then slowly gets hot. From what I have seen online it is suggested to replace the A/C Clutch but I wanted to know what do you guys think? My worst fear is that my A/C Compressor burned out because of the lack of freon but I don't know enough about the A/C system to say for sure that is what went wrong.
    I have difficulty believing a professional shop used the word "busted." It's also odd that someone mixed units (grams and pounds). Do you have their actual estimate listing what parts were faulty and what they would need to replace?
    The compressor would not engage if the pressure were outside the normal range.
    I recommend finding out high side and low side pressures first, then deciding how to proceed. There isn't enough information to figure out what's going on.
    Aug 2009
    The first shop was a firestone garage and they did use the word busted which is why I did not trust them because when i asked for proof they said "its not blowing cold" but to me they were testing this in febuary so i was a bit suspect of what they were doing.
    The second place was Tires Plus and they guy changed the digital scale from pounds to grams because the amount in the car was so low it he thought the scale was broken so he changed the scale from pounds to grams 13grams = 0.02.
    Now I just put my freon gage on my low pressure side with the temp at 101 it shows the needle right in the middle where it suppose to be but as per the gage the freon is in the red part of the gage. I can take pictures if that helps
    Quote Originally Posted by digitalbots View Post
    That is mesmerising.
    If the refrigerant level is too low the compressor should not engage at all.
    The following applies to my 2002 US model with the 2,0L engine:
    A:C troubleshooting 2002.pdf
    Aug 2009
    I think your guide would match my 2008 2.5l engine but this is what I found after driving the car for an hour.
    I will try again tomorrow when the car is cold to see if there is a difference in pressure.
    Attached Thumbnails Attached Thumbnails 20140709_213239.jpg   20140709_213334.jpg   20140709_213234.jpg
