I have to give it gas to crank my car, fuel pump?
Results 1 to 8 of 8
This is a discussion on I have to give it gas to crank my car, fuel pump? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 03 WRX with these mods -Invidia Downpipe Catted Divorced Wastegate -Invidia Racing Series Cat Back Exhaust Titanium ...
    Jun 2014
    -Invidia Racing Series Cat Back Exhaust Titanium Tip
    -No Tune........SMH
    The problem is that I have a CEL code for
    -cylinder 2 misfire
    -front O2 Sensor
    My car wont crank unless i pump the gas pedal i need to know the problem.
    I am also having some boost spikes when press the gas? Fix?
    Could it be a failing fuel pump?
    And I need to pass inspection what do I need to do to get the front 02 code fixed?
    Registered User cogito's Avatar
    Jul 2013
    Southern NH
    Check your injector/coil pack/and plug on cylinder two first, replace if necessary.
    2013 WRX Dark Grey Hatch
    1974 Datsun 260z Stroker
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by lxlouden View Post
    The obvious answer is replace the sensor.
    2002 FORESTER S
    1998 FORESTER S
    Jul 2013
    Southern NH
    o.k. but typically a O2 sensor will not cause a misfire....
    Da boonies,Va
    Quote Originally Posted by cogito View Post
    I was replying to the OP question on fixing passing inspection,but yes actually a fialing/bad front O2 sensor can cause a misfire. It controls the closed loop fueling.
    2002 FORESTER S
    1998 FORESTER S
    Jul 2013
    Southern NH
    I will have to defer to you on Subies still learning the breed, But in my experience with other makes, the misfire causes the O2 sensor to go erratic, polar opposite.
    Da boonies,Va
    Both can happen. But obviously if you already know the O2 sensor is bad then just replace it. It's not like you can't test the sensor for proper operation as well.
    OP- Read this......
    IF YOU HAVE A MISFIRE CODE ,PLEASE READ THIS!!!
    2002 FORESTER S
    1998 FORESTER S
    Jul 2013
    Southern NH
    Guess the OP will have to fill us in on final resolution.
