2005 WRX Fluid change
Results 1 to 4 of 4
This is a discussion on 2005 WRX Fluid change within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just purchased a 2005 wrx wagon and the dealer told me to change the transmission fluid. Are there any ...
    Jun 2014
    I just purchased a 2005 wrx wagon and the dealer told me to change the transmission fluid. Are there any suggestions to which fluids I should use when changing them?
    Oct 2011
    Santa Ana, CA
    Subaru 75W90 Extra-S Gear
    Jan 2012
    New Jersey
    Search Search Search hurry up and search
    DIY: Transmission Fluid Change
    Subaru Extra-S Factory Transmission Fluid you may need the torx bit for the 2005 but they site has it as a set. I would also get a funnel and some hose I forget the diameter I can check when I get back home. You may be able to get a hose around the intercooler without taking it off and if you feed enough down into the tranny so it wont fall out.
    DIY: Rear Differential Fluid Change
    you can use a 1/2in breaker bar or get the bit up to you KTC 13mm Differential Socket AC301-13 - Ultimatetoolco.com
    CFLip2x 2012 WRB WRX Build
    Feb 2014
    PNW -WA STATE - rainy side
    Here is the 13mm bung tool I used - worked GREAT:
    Amazon.com: Tool connection 1578 Drain Plug Key - 8/13mm Sq. ( Laser ): Home Improvement
    If you need a T-70, this is what I used for the tranny:
    Powerbuilt 940363 1/2-Inch Drive T-70 Bit Socket - - Amazon.com
    As for fluid I use and recommend Amsoil 75W-110 in both front and rear:
    AMSOIL Severe Gear® 75W-110
