1996 WRX STi (RHD/JDM IMPORT) NO START! FUEL RELAY? FUEL PUMP? 911-HELP!
Results 1 to 7 of 7
This is a discussion on 1996 WRX STi (RHD/JDM IMPORT) NO START! FUEL RELAY? FUEL PUMP? 911-HELP! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 96 STi no start. JDM import car that landed in Canada in Feb. 107K km, timing belt ...
    Jun 2014
    I have a 96 STi no start. JDM import car that landed in Canada in Feb. 107K km, timing belt changed at 96K. No mods. Was running fine when parked (2) days ago. Last pm no start.
    - Fuel pump not making any noise. Has 4.3V at the fuel pump plug. Hitting/tapping tank does not help.
    - Do not know where the fuel pump relay is located, JDM RHD.
    - Fuses under hood appear to be good.
    - Is there a fuse I should be looking at in panel on kick plate in car?
    - Should I pull the fuel pump and try jumping it? Can this be done with the pump in the car?
    Regards,
    temsinc
    Is the battery OK?
    Jun 2014
    Is the battery OK?
    Battery is A-ok.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Does it crank and not turn over, or just not crank at all?
    First thing to check is if it has fuel pressure at all.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Jun 2014
    It turns over normally. Spark at the coil. 4.3.V at fuel pump. Shouldn't there be 12V at the fuel pump?
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by temsinc View Post
    At least on the OBDII cars, the pump receives variable voltage from the ECU depending on the pump duty cycle.
    Facebook me here
    Jun 2014
    UPDATE:
    I think I found the culprit. Pulled the fuel pump and jumped it direct to 12V to no avail. I think she gave up the ghost.
