No boost
Results 1 to 5 of 5
This is a discussion on No boost within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 2003 wrx, no mods.Has 104000 miles. Didn't come with a boost gauge, I finally installed one and ...
    Sep 2013
    el paso, TX
    No boost
    Didn't come with a boost gauge, I finally installed one and I am pushing 5 psi in 3rd 6500 rpm. Cruzing around it fluctuates from -25 thru 1 psi and in idle I got constant -20 for vacuum. Does anyone have any insight on this issue?
    What I have tried so far is check intercooler boots they were good, throttle coupler, replace boost controller vacuum lines and all vacuum lines, replace bpv gasket, checked intercooler for cracks, replace throttle gasket.. Could it be The intake manifold and tgv gaskets need to be replace? Or bad turbo? Also white smoke comes out from under the turbo area every once in awhile, got a tear in post maf hose (part on order)and engine sounds like a old school sewing machine..are these related to the problem?? Is there any test I showed?
    Pressure/smoke test the car to check for leaks
    2005 WRX STi (Mods | Virtual Dyno) - Weekend Warrior
    Resident Tuner @ WTF Tuning
    Registered User tirerob's Avatar
    Nov 2012
    bug-eyeing in the Bakken
    super this^
    say, when you were replacing the vacuum lines on the turbo....you replaced the line that had the boost pill in it with another one or transferred the pill into the new line yes?
    when my friends come up, i hear, "you sold the camarrrroooh.....HOLY BLEEP A WRX!"
    Ya has that effect on me too.
    Rob
    Where did he go?? http://www.clubwrx.net/forums/builds...ll-thread.html
  5. #4
    Sep 2013
    el paso, TX
    Got the boost leak tester in today. So I just need to plug up all the turbo inlet holes, is the anything else?
    Ya I just transferred the pill.
  6. #5
    Moderator Donkey's Avatar
    Da boonies,Va
    2002 FORESTER S
    1998 FORESTER S
