2015 WRX Check Engine Light - Page 2
Page 2 of 10 FirstFirst 12345678910 LastLast
Results 16 to 30 of 142
This is a discussion on 2015 WRX Check Engine Light within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by MainFrame Simplest way I could think of Sent from my SCH-I545 using Tapatalk...
    Aug 2012
    Tucson, AZ
    Stinkeye member 520
    Aug 2012
    Tucson, AZ
    Looks like you're either getting a re flash or new ecm or both. Won't be coming out of your pocket either way. Irritating? Yes.
    But unfortunately these are some of the issues that come along with a first year car...you get to play guinea pig. Once they get a hold of what's causing the issue they're going to roll out and have all affected vehicles re flashed or wjatever the remedy is since this seems to be a bit on the more severe side
    Stinkeye member 520
    May 2014
    Yeah, thanks for the replies guys
  5. #19
    Aug 2012
    Tucson, AZ
    Be patient, it's a new car to everyone. It'll be figured out. In the meantime keep us posted
    Stinkeye member 520
  6. #20
    Registered User Raven Logics's Avatar
    Dec 2007
    Canada
    Quote Originally Posted by Sillywabbit View Post
    They had a Subi engineer drive a few hundred miles to collect data and figure out what was wrong with the vehicle.
    A few hundred miles? WTF??? You're either trolling or you've been taken for a ride. Assuming it's the latter, I'd complain to SOA and ask them to pull the data logs for how the car was driven during that time. If that engineer was not careful during your break-in period he might have void your engine warranty. At least make sure it is documented that the dealership drove the car for those miles.
    What are your local lemon laws? That would also be interesting to know, although I would use it to get a new car rather than remind them about it.
  7. #21
    May 2014
    Well I'm definitely not a troller. I did research the NV lemon laws and the car would've had to be inoperable for 30 days, which at this point it's going to be 15 by the time I get it back, or have been taken in 4 times for the same issue or related issue. I have all the paperwork that they gave me explaining the codes. The first code was a p2610 and that was ECM. Now they're saying it's a P0606 code which is CPU failure. I did contact SOA and the Senior Customer relations director is supposed to call me tomorrow. I really hope they don't BS me because I'm very stubborn and short tempered and they are wearing me thin.
  8. #22
    May 2014
    Oh and when I said a subi engineer drove a few hundred miles, I meant he drove a few hundred miles to look at my car, not he drove my car for a few hundred miles. Lol I guess I worded that wrong!
  9. #23
    Apr 2014
    OK, just to clarify, no, it's not a virus. A virus is a piece of malware/malicious code written to do something, well, malicious. What the OP is dealing with is a bug. A defect in the code.
    OP, before you go nuts, things like this happen. A lot. Things slip past QC/QA. You don't need a whole new car because of a software failure. If the failure can be linked to a physical failure, you may have a case but it's unlikely given the many failsafes in modern ECU's.
    Also, the easier you are to deal with, the more likely you'll be compensated. Irate, pissed off, fuming customers don't get the grease. Be firm about your stance but calm and collected.
    Sent from my SM-N900T using Tapatalk
  10. #24
    Registered User BigPoppaSteve's Avatar
    May 2014
    Quote Originally Posted by ProTekk View Post
    This guy knows his stuff. Heed him.
  11. #25
    May 2014
    Ok, that makes sense. Wouldn't the fact that the car wouldn't go past 23 and then 10mph be a Physical failure of some sort? What would have made the RPMs go crazy and no acceleration?
  12. #26
    Apr 2014
    That would be the ECU failsafes doing their job. The ECU saw certain conditions that were outside "safe" parameters and cut power/acceleration where needed to avoid nuking your engine.
  13. #27
    May 2014
    Thanks Protekk, I appreciate the explanation
  14. #28
    Sep 2004
    So Cal
    I can tell you from experience that staying calm and professional, but being firm, will get results. The fact that they are absorbing your next payment is encouraging. I agree with others that the WRX (and competitor GTI) are clean sheet of paper designs and issues are almost expected. Keep in mind that the average new car is assembled with roughly 30,000 separate parts if you count all the screws, washers, etc.
  15. #29
    May 2014
    Ok, I will remember to keep my calm.
  16. #30
    Apr 2014
    Truthfully, reading all of that while drinking gave me a migraine but i caught the basic outline of the post. Did they say what may have caused the issue and how long it will take to fix?
    Hopefully everything works out.
