Oil question ( I checked the sticky and couldn't find an answer on this)
Results 1 to 6 of 6
This is a discussion on Oil question ( I checked the sticky and couldn't find an answer on this) within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey guys, first time poster and new owner of a 2011 wrx hatch back! I'll post some pics after work... ...
    May 2014
    Anyway, this may seem like a dumb question.
    I bought the car used at 38,000 miles and the dealship said they were un-aware of what type of oil the original owner used. My question is, if I switch to a synthetic oil like amsoil, would it cause any leakage through my gaskets? I was told that if you use a low quality oil and then switch to a synthetic, the molecule structure is much smaller and you will have oil leaking out through all your gaskets.
    Is this true and should I be concerned with switching oils?
    Thanks so much in advance guys!
            MainFrame's Avatar
    Austin, TX
    AFIK, the car should have come from the factory with synthetic already in it.. it says use synthetic only in the manual, the previous owner probably used synthetic.. I would put synthetic in it.
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Quote Originally Posted by Jitsu1 View Post
    Well, the previous owner SHOULD have been using full synthetic from the beginning, since Subaru has required full synth in the WRX for quite a few years now. I'm not sure about the gasket question, but I've never heard that.
    No need to use Amsoil. Valvoline Full Synthetic works great, is available everywhere, and is much cheaper.
    2007 Outback 3.0R wagon
    Palmyra, NJ
    It should have been running Synthetic from the start, from the factory. So I think at that low of mileage, you'd be safe. Just stick with a good quality synthetic and you'll be fine. I wouldn't worry about any kind of leakage at 38k miles.
    Many people run Shell Rotella T6 in 5w40...after many oil analyses, people find this to be one of the better ones. And its actually one of the cheaper ones.
    May 2014
    Awesome
    I really appreciate the feedback guys!
    @Mikie13,
    I live down here in FL, would the fluctuation in temperature from NJ to FL affect the oil viscosity you recommended?
    Jul 2012
    Rocky Top
    Unless you're going from FL to AK, or AZ to NJ, or racing; there's not a big need to change the viscosity.
