2002 WRX sloppy shifter
Results 1 to 9 of 9
This is a discussion on 2002 WRX sloppy shifter within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; All the gears are there, it drives fine, just there's a ridiculous amount of shifter play. Video: https://www.youtube.com/watch?v=8CUXdFIvXZI...
    May 2014
    New Jersey
    Video:
    Moderator Donkey's Avatar
    Da boonies,Va
    Get some shifter bushings. Kartboy,Superpro and Energy Suspension all make some.
    2002 FORESTER S
    1998 FORESTER S
    May 2014
    New Jersey
    thanks, ordered some kartboy bushings earlier today
            MainFrame's Avatar
    Austin, TX
    Bushings, both front and rear.. for side to side play, check into this: TiC 5MT Linkage Update
    May 2014
    New Jersey
    Yeah I went under the car the other day and it looked like the bushings weren't moving, but the linkage joint as well as the bar that attaches to it were
            MainFrame's Avatar
    Austin, TX
    If they're stock bushings they might not look like they're moving, but they make the shifts feel all spongy. New bushings will make shifts feel crisper, and the linkage update will reduce play.
    May 2014
    New Jersey
    UPDATE: installed a new u joint and everything is still exactly the same in terms of looseness and slop
            MainFrame's Avatar
    Austin, TX
    Sure there's not something broken in the linkage? I just now watched the video and something is definitely broken..
    May 2014
    New Jersey
    I thought that at first also, but wouldn't that mean I wouldn't be able to shift all gears? All gears work and everything and the joint I replaced was definitely worn to hell. Could it be something as small as missing the return spring? It definitely doesn't have a return spring
