New 2015 WRX Limited Average Idle Range?
Results 1 to 10 of 10
This is a discussion on New 2015 WRX Limited Average Idle Range? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a question about the idle range of my 2015 Subaru WRX after it has been sitting overnight. Here ...
    Registered User Jcoyle90's Avatar
    Feb 2014
    Colorado
    Here are the facts: I just picked up a '15 Subaru WRX Limited with CVT and it seemed as though the idle speed - the car is started cold (~72 degree ambient temperature in the garage) - is relatively high (1,500 - 1,800 RPM) and remains there until I start driving. Once I start driving, if I come to a stop, the tach reads <1,000 RPM and feels normal. It has done this twice now (<250 miles on the car so no gas fill-up except the one from the dealer).
    We had a Jetta that would run a higher idle speed for 30-45 seconds and then cut down to normal. Is anyone else experiencing this? Is this a normal idle when you start the car with a Subaru? Does it drop down after a few minutes? We don't let our cars idle for more than a minute or two.
    I am new to this forum, so I apologize if I posted in the wrong place
    Registered User Scoob1318's Avatar
    Apr 2013
    That's the same range my 2013 wrx idles at. Takes my car a while to get down to normal idle range on a cold start unless I start driving right away.
    Hammerdown Mod of Thunder josnroh's Avatar
    Feb 2003
    oHIo
    Same thing in my '15,normal.
    JOE/Flyin' Under the Radar
    2015 Buckeye Boxer WRX
    2003 Hammerdown Wagon WRX(sold)
    1983 GL-10 Wagon (RIP)
    Sometimes you get the best light from a burning bridge.
    http://badges.fuelly.com/images/sig-us/282947.png
    Apr 2014
    Crofton, MD
    I was wondering this as well. My '15 WRX 6sp hangs out around 1500rpm for several minutes until it finally calms down. Is it ok to drive off before the idle comes down to "normal"?
    Second related question. After warming the car up then coming to a prolonged stop (say parked with the engine on and trans in neutral) the rpm's will settle at just about 700 and feel right, but dip every few seconds to about 600 then jump back to 700. Gives me the initial feeling like the engine is about to stall. I notice the vacuum drops and jumps simultaneously as well.
    Registered User trama's Avatar
    May 2014
    Sonoma coast, CA
    Re: rpms at idle
    Quote Originally Posted by Phileas View Post
    First; I think high idle is normal until system gets warm enough for O2 sensor to start working.
    Second; Dipping rpms at idle: It is probably just your ACC/CF kicking in.
    Last edited by trama; 05-02-2014 at 11:15 AM. Reason: Oops, first post evar on here plz forgive
    Apr 2014
    BROlando
    Quote Originally Posted by trama View Post
    My 15 does the same. 1500 for 30 secs to 1 min, drop to 600 afterwords.
    Sent from my DROID RAZR HD using Tapatalk
    Sep 2014
    My 15 limited does the same thing, sometimes when its cold in the morning it will do it for about 1 and 1/2 minutes, other times may be 30 seconds are less depending on how long the car has been sitting. Completely normal on turbo cars and you should allow it to warm up and idle down before driving.
    Registered User Goose42's Avatar
    Jun 2014
    PNW
    Pretty much agreeing with all input. OP, when you first do a cold start, let the car warm up until the revs drop. But, keep in mind, the coolant will come to temperature before the oil, so do not hoon it straight out of the driveway.
    Or he is rolling down the street in his new slammed ride vaping out the window, enjoying the tow truck ride. - XJman
    2017 ISM Impreza 5MT Hatchback Sport
    2015 WRX COBB Surgeline Stage 2 Pro Tune (Sold)
    Journal-
    http://www.clubwrx.net/forums/builds...ml#post3579257
    May 2015
    In regards to your second questions I recently got a Subaru wrx with the cvt and today when I sat in the car after it warmed up, the idle went to that and I also got the feeling it would stall
    Jul 2014
    McHenry
    What about vac pressure on the boost gauge what should that be at?
