Check Engine Light - Ethanol in gas
Results 1 to 8 of 8
This is a discussion on Check Engine Light - Ethanol in gas within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I've been having a weird idling problem intermittently. It is occasionally very rough, and I can feel something going on ...
    Registered User Hank_VA's Avatar
    Nov 2012
    Central, VA
    I've been having a weird idling problem intermittently. It is occasionally very rough, and I can feel something going on sometimes under acceleration ... like a misfire or something.
    The car has been to the dealer 2 times now for the same code, and their explanation (this time) is that I have ethanol in my fuel and I need to find a different gas station/brand. Given that I don't buy just one name brand, depending on where I am, I have no idea what to do. When I told the service rep that, he repeated himself.
    They gave me my car back today with those instructions. And if I have the problem again they will investigate further.
    1. Is this hurting my car?
    2. What can I do about it?
    3. Is there an additive that can help with this?
    Thanks.
    Registered User Obeisance's Avatar
    Apr 2012
    not Ann Arbor
    What is the code of the CEL? Can you get access to an ECU logging solution?
    David - '05 WRX
    Quote Originally Posted by Hank_VA View Post
    Ask in writing for a statement saying Subaru of America does not believe the fuel sold in station X (fill in the blank) meets the legal requirements for gasolines sold in the United States.
    If they don't give you that have them fix your car under warranty.
    Nov 2012
    Central, VA
    The code is P0300 - Random Misfire. I don't have access myself, but this is the code the dealer put on my receipt.
    At the moment, they just told me to drive it and if it does it again, bring it back and plan on leaving it. The service rep was a tad robotic about "Find another gas station".
    Moderator Donkey's Avatar
    Da boonies,Va
    They are morons. E10 is not going to create that kind of problem.
    IF YOU HAVE A MISFIRE CODE ,PLEASE READ THIS!!!
    What mods are on the car? Need mileage,year.......
    http://www.clubwrx.net/forums/genera...-question.html
    2002 FORESTER S
    1998 FORESTER S
    Nov 2012
    Central, VA
    I never seem to do this right.
    2013 WRX w/ 26000 miles on it. Completely stock.
    Thanks for the info, it's been helpful. I talked with Subaru USA and they're supposedly going to talk to the service dept. to see what's going on, and why multiple trips for the same problem is going on.
    Da boonies,Va
    I would try cleaning the factory engine grounds,battery terminals or even adding a grounding kit and see if that helps. All gas station in VA,as far as I know,use E-10. The thing using a Tier 1 gasoline does is guarantee a good additive/detergent package.
    2002 FORESTER S
    1998 FORESTER S
    Nov 2012
    Central, VA
    This is a really late reply to this, but I wanted to follow up with what wound up being the issue.
    The problem went away for a couple of months, came back, and I took it back in again.
    The Techs replaced the engine wiring harness and the car has been running awesome since.
    Go figure that the original diagnosis of bad gas, turned into a wiring harness problem, with the exact same symptoms.
