MAF or tps? Help troubleshooting 03
Results 1 to 5 of 5
This is a discussion on MAF or tps? Help troubleshooting 03 within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey guys, I'm having a small problem with my car and I want to say it's either the throttle position ...
    Registered User ANoLEN's Avatar
    Mar 2014
    Shawnee, OK
    Hey guys, I'm having a small problem with my car and I want to say it's either the throttle position sensor or mass air but id like some opinions from more experienced owners.
    At either 2k or 2500 rpm, usually in 1st-2nd gear, it kind of hiccups like it's not firing correctly for a split second. It's nothing violent and it's very quick, but I can feel it and it feels just like my old 240sx did when it's tps and maf were both going out.
    If anyone has thoughts on which one it might be it would be greatly appreciated, I would hate to spend $100+ on either one and then have it turn out to be the other
    Mar 2014
    Shawnee, OK
    Also, I just ran a can of seafoam through the gas and the correct amount in the oil. The problem started before the seafoam and doesn't feel any different after.
    Registered User Obeisance's Avatar
    Apr 2012
    not Ann Arbor
    Can you get access to some kind of data logging solution? That may help you troubleshoot. Even a vag-com cable and romraider work for me:
    Amazon.com: KIA 20 Pin to OBD Obd2 Obdii DLC 16 Pin Car Diagnostic Adapter Converter Cable (Blue): Automotive
    David - '05 WRX
  5. #4
    Mar 2014
    Shawnee, OK
    Hadn't thought about that, I'll check it out.
  6. #5
    Mar 2014
    Shawnee, OK
    Seems like it's only happening with the a/c on too. What could that mean?
