Boost Gauge... is This Normal!? - Page 2
Results 16 to 30 of 32
This is a discussion on Boost Gauge... is This Normal!? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; heres a pic i just took of the gauge sitting at idle...
    Feb 2014
    Philly Suburbs
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by Clarkiss View Post
    1. The units are likely inHg
    2. That is a VACUUM GAUGE not a boost gauge. That's essentially useless for your application. Sure it reads + over atmospheric pressure, but look at the gauge ranges: + 20 inHG is only 9.85 PSI. You'll max out the gauge at just a bit over wastegate pressure.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    <-------- Taylor Swift.
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
  6. #19
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by lytlec View Post
    Wait, Vacuum is represented in different units from boost? That's easily one of the most idiotic product design I've ever seen.
    And of course, no units on the dial face. Whoever designed that product should be forcibly retired.
    Facebook me here
  7. #20
    Jan 2009
    Central PA
    You're fine. Nothing wrong with your gauge. I have a prosport and it does the same thing.
    Subaru Guide
  8. #21
    Jan 2009
    Central PA
    Wait, Vacuum is represented in different units from boost? That's the most idiotic product design I've ever seen.
    That's how the prosport boost gauges are.
    Subaru Guide
  9. #22
    zax
    zax is offline
    Nov 2008
    No surprise there. Prosport is also garbage.
    Facebook me here
  10. #23
    Jan 2009
    Central PA
    Ha yep. I thought it was the norm though. I'm too cheap to upgrade. I figured once they stop working I'll upgrade them one by one.
    Subaru Guide
  11. #24
    Registered User jas280z's Avatar
    Mar 2012
    WNY
    That (inHg and PSI) is how the SPT gauge is on my WRX as well. You can quickly tell as the scales are different on one side than the other. To be honest the setup always seemed intuitive to me, as I am used to dealing with vacuum in inHg and boost in PSI.
    I do agree that all gauges should have units, mess up your units and your fancy Mars orbiter turns into an Intra Solar System Ballistic Missile. It is kind of hard to see here, but the SPT does have units: http://i.imgur.com/5dTEV.jpg .
    2012 Base WRB WRX Hatch Stock
    1978 Datsun 280z Fully restored and lightly restomodded: http://www.zcar.com/members_rides/no..._890384.0.html
  12. #25
    Moderator Donkey's Avatar
    Da boonies,Va
    You been drinking early today ?I have never owned a boost gauge that didn't express vacuum in inHg and PSI in boost. In fact expressing vacuum as negative psi is absurd. I have used vacuum gauges in my NA cars for over 25 years and they all read inHg. Unless we are looking at a different pic, the units are expressed on the gauge face.
    2002 FORESTER S
    1998 FORESTER S
  13. #26
    Damned Malcontent shamankjm's Avatar
    Dec 2010
    East Taut'in, Massachusetts, United States
    My AEM digi gauge must do the same thing in regards to units of measurement since I'm around 20 at idle.
    Sent from my iBone
    Kartboy STS, related shifter/linkage bushings, Whiteline subframe bushing inserts, Whiteline rear differential bushing inserts, Whiteline steering rack bushings, Grimmspeed MCB, Group N tranny mount, TiC tranny cross member bushings, gimmick turbro inlet pipe, Ingen intake, PW-clone TMIC, Turbrosmart BPV, Megan catless DP, Tsudo N1 exhaust... X-wing dangly and dashboard Buddy Christ (for lulz)
  14. #27
    A mixed unit gauge with mmHg and PSI is absurd but common... From memory, even the OEM Porsche VDO gauges for the turbo 4cyl motors were mixed unit gauges.
    Why not just use Pa or bar?!
    Anyway, OP, you're reading different units in vacuum vs in boost.
  15. #28
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    I'm surprised someone with a graduate degree in physics has never seen vacuum represented in inHg.
    While agree that the units should be labeled on the gauge face, I've never seen an Imperial unit manifold pressure gauge that didn't use inHg for vacuum and PSI for positive pressure. Both my Prosport and Defi manifold pressure gauges used that notation (both had the units labeled), so brand quality didn't have anything to do with notation.
    That said, the term "boost gauge" applied to these gauges is a misnomer. A true "boost" gauge would only read from 0-XX positive PSI. VDO makes just such a gauge: Boost | By Type | Instruments | VDO Instruments and Accessories
    VDO describes the vacuum/positive pressure gauges as "turbo gauges": Turbo | By Type | Instruments | VDO Instruments and Accessories
    2007 Outback 3.0R wagon
  16. #29
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by Rambo View Post
    Can't tell if belittling...
    For all intents and purposes, "boost" and "vacuum" are simply measurements of manifold absolute pressure. I would expect measurements of the same quantity to be represented in consistent units. In physics, if unit conversions are not properly obeyed, one can expect to have a bad time. Simplicity is key my friend.
    Of course I've seen units of pressure represented in inHg (more typically Torr), as I've seen units of pressure in PSI. That is no excuse to use units inconsistently, especially without labels.
    My gauge, while represented in Pascals, uses consistent units above (boost) and below (vacuum) atmospheric pressure. This is something I appreciate.
    Facebook me here
  17. #30
    zax
    zax is offline
    Nov 2008
    Yet another reason I despise the inconsistency of Imperial units.
    We are clearly looking at different pics.
    How is negative PSI any more absurd than negative inHg? Both are merely units of pressure. This is nothing less than carryover from people classically referring to vacuum in inHg vs. Boost in psi.
    I agree with Spiro: multiunits is absurd.
    Facebook me here
