Power Steering Squeaking and Stiffness
Results 1 to 15 of 16
This is a discussion on Power Steering Squeaking and Stiffness within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; The power steering squeaks and squeals on startup when cold. Furthermore, it is very stiff and difficult to turn the ...
    Registered User Hobbitrabbit's Avatar
    Jan 2014
    Cincinnati
    The power steering squeaks and squeals on startup when cold. Furthermore, it is very stiff and difficult to turn the wheel when it is cold. I had heard this could be a belt issue so I tightened it, but nothing changed, and the problem seems to be getting worse. How do I determine if I need to replace the belt, or if the pump itself is bad?
    Village Idiot McBill's Avatar
    Sep 2013
    Buckeye State
    what year is the car and how cold are we talking here.
    Billy
    2009 Ducati Monster 1100
    2008 Legacy 3.0R - SOLD
    2011 WRB WRX Sedan - SOLD
    Stink-Eye Mob #696
    Facebook
    Jan 2014
    Cincinnati
    It's an 04, talking like 20-30 degrees. Not terribly cold. It was 60 here about a week ago (Ohio weather is ridiculous) and it was still squeaking.
    Sep 2013
    Buckeye State
    Yes, believe me i know (Columbus here). Any how, does it sound like a belt squeal? because if so it could very well be the belt. But the stiffness could be a whole other issue. Have you checked your fluid levels? does it make like a wyning or moaning noise?
    Billy
    Stink-Eye Mob #696
    Facebook
    Jan 2014
    Cincinnati
    Cinci here! No whining, no moaning. I'm thinking it may be the belt, but tightening/loosening it hasn't done anything and it doesn't appear to be worn. It's just a repeated squeaking noise that goes down in pitch and frequency when I start to turn the wheel, and the wheel doesn't turn very easily until it warms up and the squeaking stops.
    Sep 2013
    Buckeye State
    Quote Originally Posted by Hobbitrabbit View Post
    Just sounds like an old belt. Replacing the belt will probably fix the problem. Tightening probably wont solve the squealing problem on a worn down belt.
    Billy
    Stink-Eye Mob #696
    Facebook
    Jan 2014
    Cincinnati
    Okay. That's not a terribly complicated job, but is there anything in particular I should know about doing that?
    Sep 2013
    Buckeye State
    I'm not sure about that. I haven't had to change the serpentine belt on my Subaru yet.
    Billy
    Stink-Eye Mob #696
    Facebook
    Oct 2011
    Santa Ana, CA
    My power steering pump did the same thing before it died.
    2005 WRX here.
    Sent from my DROID2 Global using Tapatalk 2
    Palmyra, NJ
    First thought is PS pump is dying...but it is the cheaper thing to rule out and replace belts...
    Jan 2014
    Cincinnati
    Really hoping the pump isn't dying, so yeah, will be replacing belts to rule that out.
    Registered User Obeisance's Avatar
    Apr 2012
    not Ann Arbor
    Mine was slipping a month or so ago (in the super cold, -30 F weeks) giving the symptoms that you observe. It would squeal upon startup and steering would be difficult. Then, as the car warmed up it silenced and things got better. I could see that it was slipping because there was polished metal on the pulley under the belt. I tightened it and my problem has not come back, in spite of the returning cold.
    David - '05 WRX
    Jan 2014
    Cincinnati
    Tightening hasn't done anything for me so I'm assuming the slippage is from a bad belt.
    Nov 2013
    Could be a small o ring on the pump inlet. i had the same problem looked it up on youtube. found a video that had dimensions on a new one wen't got one from a ace and fixed the hole problem only 68 cents. if its still doing it i could give you the link to the video. it also shows you how to replace it.
    Sent from my DROID RAZR using Tapatalk
    Using Tapatalk
    Mar 2014
    Boston
    This happened with my friend's '03 WRX. Before it warmed up it would squeal and it was like the power steering wasn't working at all. What was weirder was that if he fired it up and it sqealed. If he shut if off immediately and started it back up, it would run fine with no issue and the engine would still be cold.
