AC Compressor will not turn
Results 1 to 7 of 7
This is a discussion on AC Compressor will not turn within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; info: 2007 STI, all Stock 65k mileshey guys so yesterday while driving the temperature got a little warm so i ...
    Registered User RogerSteadman's Avatar
    Jul 2012
    Pflugerville, Texas, United States
    Question AC Compressor will not turn
    info: 2007 STI, all Stock 65k mileshey guys so yesterday while driving the temperature got a little warm so i turned the AC on, well i didn't hear it click on and put load on the engine like normal and the air never got cold, so i turned the ac button off and drove it home. When i got home i looked at the engine with the AC off and everything is spinning fine except the AC of course, all the pulleys are moving fine, no issues what so ever.now when you click the AC button on, it looks the exact same, no difference, the pulleys all spin, but the front of the AC compressor does not Spin, at all but the pulley does, and furthermore, you can take your hand or a screwdriver or wrench or anything and touch the front of the compressor and you can spin it freely, when its on, or off, it is exactly the same, i live in south Texas and i have two little kids so i cant be without AC any ideas what this problem could be?
    Dont buy cheap ebay knockoffs, thats disgraceful to the Subaru you drive, its not a rice rocket, and you're nota Ricer and it has the possibility to be broken more easily. - Roger
    Registered User Obeisance's Avatar
    Apr 2012
    not Ann Arbor
    Here are some dumb questions: Have you turned the thermostat temperature setting in the car as cold as possible? In my car, the A/C clutch will not kick in unless a significant draw is needed. Also, how do all of the fuses look? When you push the A/C button, can you hear a relay switch on?
    David - '05 WRX
    Jul 2012
    lol yes when i press the button to turn it on the thermostat is set all the way down to the lowest temperature it was 89 degrees yesterday so it should have blown cold, i didnt check the fuses or anything and no when i pressed the button i heard no click no engine rpm change nothing and i could still spin the front of the compressor both directions by hand
    The compressor will not engage if:
    - There is no power to it or to its switch.
    - The compressor clutch has failed.
    - The refrigerant pressure is too low.
    So make sure you don't have a leak and check the electrical connections plus fuses.
    Apr 2012
    not Ann Arbor
    Also, 89°? That sounds nice. I miss taking a drive with the windows down. This past weeks forecast: thunder snow.
    Apparently that is a thing in Michigan.
    David - '05 WRX
    Dec 2013
    Grand Rapids, Michigan, United States
    Nothing to contribute, but the thunder snow was cool. Lol. Im up in the keweenaw. We also had almost 50° weather, good windows down weather
    Jul 2012
    so how do i check if a relay is good or not, i know how to check Fuses of course, but not relays? and how much pressure of coolant should i have? what is normal
