Rebuild issues?
Results 1 to 2 of 2
This is a discussion on Rebuild issues? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Okay so here is what happened. I wasn't sure where to put this first off. Alright, a while back my ...
    Apr 2007
    Florida
    Rebuild issues?
    Okay so here is what happened. I wasn't sure where to put this first off. Alright, a while back my 03 WRX timing belt tensioner bolt backed out took out the belt and all 16 valves in the process. After pulling the engine having a machine shop replace the valves and also taking care of a few things that were wrong while the engine was out I finally got it back in the car. Here is the issue that i'm having. After getting the car running again the IAC valve threw a code. I took it apart and cleaned it with no code now. The engine seems like it is missing and has a little shake at low rpm and a little back firing. In the upper rpm's everything smooths out. The up stream O2 sensor is bad and I know that, but it was bad before all of this and it ran fine. The car sat for about 1 1/2 years and we used the pressurized fuel rail/injector setup with 4 cans, but had no effect on how it was running. Before the engine went away I had a code for the O2 sensor and tgv stuck open. While it was down I replaced the tgv electronics and have no code for that anymore. With what seems like a miss there are no codes that pop up. Also the rpms at one point are at 450 or so then the next time you start the car they are at 850 with no changes anywhere. Could the IAC still be the issue, but not setting a code? Both myself and the other guy are certified techs and he has been one for about 20 years or so. This has both of us scratching our heads trying to figure it out. Any information would be helpful. Thanks, Rob
    Moderator Donkey's Avatar
    Da boonies,Va
    I would recheck the engine grounds. A small vacuum leak could be possible. Have you checked what the fuel trims look like?
    2002 FORESTER S
    1998 FORESTER S
