E brake and battery light
Results 1 to 14 of 14
This is a discussion on E brake and battery light within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; starting about two months ago when id come out and start my car and drive to work. i noticed that ...
    Aug 2013
    starting about two months ago when id come out and start my car and drive to work. i noticed that the steering would be hard and that the e-brake and battery light would come on in the dash but by the time i was out of the parking lot it would go off... but today was different, today i was half way to work when it happened and it continued on all the way into work.
    any ideas? i thought maybe the power steering fluid was low so i check it and its between the lines so its fine and i have no idea what could cause the lights to come on
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    I think the problem is that you might be having issues with your alternator (the alternator might be not working well enough to charge the battery). The battery light will typically come on when the car is using power from the battery as opposed to charging it. How old is your car?
    Aug 2013
    Baltimore County Md
    Agreed! Get that alternator checked. If it is the issue, also have the battery tested because if its not being charged, its being weakened, and the battery will die soon.
  5. #4
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    The brake light will come on if the car detects low fluid in either the brake or power steering reservoir. I don't know the cause for the battery light, but I'd suspect precisely what 11BlackSTi has suggested.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  6. #5
    Aug 2013
    ok thanks guys ill check that when i change my oil tomorrow
    its an 04 if that helps at all
  7. #6
    Aug 2013
    ok my car was showing some more symptoms on the way home from work this morning that id say confirms the bad alternator. the ABS light came on, the windshield wipers were moving very slow and the gauges in the dash were bouncing
    do you guys agree?
  8. #7
    Nov 2012
    Yeah you need to get the alternator checked out and fixed if that is the issue. Also get the battery tested as previously mentioned above. The alternator is most likely not functioning properly and you are losing power over time from the battery. Your battery might end up needing to be replaced too depending on how old it is. Let us know what ends up happening.
  9. #8
    Registered User jtk07's Avatar
    Aug 2013
    North Dallas
    It could also be a bad cell in the battery. Used to have a car that killed 2 alternators before we replaced the 3rd alternator and battery. Have them do a load test on the battery also.
    ~Tyler K~
    Sent from my iPhone using Tapatalk please disregard typos!
  10. #9
    Aug 2013
    ok i used my voltmeter and found that with the car off the battery was sitting at 12.4 volts and then when i started the car is dropped and stayed at 11.3
  11. #10
    Aug 2013
    pulled the cover to take the alternator off to go have it tested or get a new one and found that one of the belts had broken so now i have two new belts and am replacing them. thanks guys for the help
  12. #11
    Aug 2013
    Baltimore County Md
    Wow, well that explains the hard steering.
  13. #12
    Aug 2013
    yeah im glad i checked it out... should have done that sooner
  14. #13
    Aug 2013
    Baltimore County Md
    You live and learn brother.
  15. #14
            MainFrame's Avatar
    Austin, TX
    Yep.. alternator AND power steering problems = accessory belt
