Stock boost question?
Results 1 to 15 of 16
This is a discussion on Stock boost question? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So I have had my 2014 wrx for about a month and a half. It's at about 1700 miles on ...
    Dec 2013
    So I have had my 2014 wrx for about a month and a half. It's at about 1700 miles on it. Two days ago the dealership replaced my spt boost gauge with a new one cause it rattled. Well I noticed now it's going to 16 psi then at 4500rpms it dropped down to around 12. Idk if the gauge is wrong or if that's normal? Thanks for the help and sorry if this a dumb newb question.
    Dec 2013
    Boost tapers off as you get closer to redline with the stock turbo and stock tune. Go Stage 1 if you want to fix this.
    Sent from my LG G2 using Tapatalk
    Dec 2013
    Ok that's kinda what I thought and I plan to go stage 2 just want to let the car get some miles and make sure all is good before I start messing with anything. Thanks for the help
    Registered User spotsywrx's Avatar
    Aug 2013
    spotsy/farmville va
    Even when tuned these cars will lose boost higher in the rpm range.
    2011 Wrx Limited Sedan Silver. Nameless muffler delete, Kartboy Short throw w/ cobb knob, Rally Armor mud flaps, 30% tint... Goodbye warranty Cobb AP v3 and Sf intake. Stink-eye mob #1993
    Dec 2013
    Quote Originally Posted by spotsywrx View Post
    True. I believe the amount that is lost is much less with a tune though, correct?
    Aug 2013
    spotsy/farmville va
    I can't give you exact numbers because I did not have a boost gauge before I was tuned. I have a stage1 tune with the sf intake by cobb and peak at 17.8 by redline I'm around 14.
    Dec 2013
    So the percentage loss may be about the same, I think with the stock tune boost tapers off to around 12 PSI by redline.
    Aug 2013
    spotsy/farmville va
    I believe it should be about the same. Stock is what? Upper 14's?
    Dec 2013
    Not at redline.
    Palmyra, NJ
    Stock boost is between 13.5-13.9psi and should taper down as it approaches redline.
    Dec 2013
    14.2 for WRX, 14.7 for STI.
    Palmyra, NJ
    Quote Originally Posted by techguymaxc View Post
    Oops...was thinking of the GDs. Maaaaaah bad.
    Jan 2012
    Philly Area
    You don't even HAVE a GD anymore, MIKIE.
    - Will
    Stock boost:
    Unless you are running extremely low boost targets, the turbo will taper towards redline. In general, on pump gas, turbos are going to typically naturally taper to 14-15PSI by redline.
    On a S1 tune, you can usually let the turbo taper fairly naturally and have fueling stay in line. On a S2 tune, you usually have to get a bit more aggressive with the taper (to keep IDCs down). With an intake on either, you need to taper more aggressively. With additional fueling, you can let the turbo taper naturally.
    Resident Tuner @ WTF Tuning
    Palmyra, NJ
    So I was right being closer to 13.5...
