2008 WRX Losing Power
Results 1 to 15 of 15
This is a discussion on 2008 WRX Losing Power within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My wife was driving her 2008 WRX late last night and the engine suddenly lost power. She had driven 20 ...
    Jan 2014
    My wife was driving her 2008 WRX late last night and the engine suddenly lost power. She had driven 20 highway miles and the check engine light came on and the “cruise” light began flashing. She didn’t have far to go and it was 10 degrees Fahrenheit so she limped home.
    I tried it today and it is still running at about half power. There is also a “whirling” noise that is not normally there.
    We live in the country and don’t have a “trusted” mechanic close by -- so any input before we have it towed somewhere would be appreciated.
    It has 114K miles on it and, other than regular maintenance, we have had no problems with it. The battery is new and all of the fluids are OK.
    Thanks in advance for your help!
    BNEX
    Jan 2012
    Philly Area
    Very difficult for us to diagnose what's going on. The car entered "limp mode" to protect itself, but there are a variety of things that could cause that. Do you have any way you can get the CEL code read?
    - Will
    Jan 2014
    I just got a referral for a reliable mechanic. My previous one moved out of town. Is it possible for me to drive it 6 or 7 miles safely?
    Registered User jtk07's Avatar
    Aug 2013
    North Dallas
    If you drove it very carefully I would think hat you could make it. Without hearing tho is the concern.
    This safe mode is designed to get you safely to a shop or home. I would however use your best judgment. If you have towing on your insurance or aaa use it and be safe.
    ~Tyler K~
    Sent from my iPhone using Tapatalk please disregard typos!
    Palmyra, NJ
    Quote Originally Posted by BNEX View Post
    Those 6 or 7 miles could mean the difference between a car needing work or a car needing an engine replacement...if you don't know what it did to lose power, I wouldn't drive it anywhere, especially without knowing the codes thrown.
    Jan 2014
    East Coast
    Whirl noise makes me think intercooler hose came loose or is cracked/damaged. If this is the case, it should be ok for a few miles but, change your plugs as they may foul out from running rich in limp mode.
    Good luck!
    Chris
    '14 WRX Crystal Black/SPT CBE/Tuned by Torqued Performance
    Nov 2013
    Dose the 2004 have any mode like that i have the same problem has no power car seems likes it has a fuel cut but that could be from running Rich with only 5 psi going in to it it normally ran around 10psi
    Sent from my DROID RAZR using Tapatalk
    Using Tapatalk
    Aug 2012
    Tucson, AZ
    Quote Originally Posted by Bbanks View Post
    If you start your own thread you may get more input...not nice to thread jack
    Again though, no one can really help you without knowing if there's a code or not. Assuming you're running that low of power chances are you should have a cel
    Sent from my SCH-I545 using Tapatalk
    Stinkeye member 520
    Nov 2013
    There are no codes thrown on my AP but i can't get my AP hooked up to my computer that's a hole mother story
    Using Tapatalk
    Aug 2012
    Tucson, AZ
    Alright, so if there's no cel light right now, the car doesn't notice this as a problem. First thing you should check now are vacuum lines, intake hoses, etc. Possible boost leak
    Stinkeye member 520
    Nov 2013
    Ok will do as soon as i get off work tomorrow. i have one more question if you wouldn't mind. I'm getting a td05 16g turbo soon for it manly because i thought the turbo went out lol. What Would be a good fuel pump upgrade size be for that turbo if I'm planning to run 20 psi?
    Using Tapatalk
    Aug 2012
    Tucson, AZ
    I don't exactly know to tell you the truth. A 16g isn't too too big and I know a lot of people run the 255 fuel pumps so I know that's what I'm going to do. You'll also want to run bigger injectors.
    There's plenty of options out there, but it's ultimately going to come down to what your plans are for mods.
    If you have a good local tuner around, stop by or give them a call. Especially since you're going to need a pro tune for a bigger turbo and fuel pump
    Stinkeye member 520
    Jan 2014
    East Coast
    Quote Originally Posted by chris410 View Post
    Good luck!
    Following up on my own post....If you do not know the exact problem, have it towed to avoid any risk of further damage.
    Chris
    Nov 2013
    Will do thanks I'll look in to some
    Using Tapatalk
    Aug 2012
    Tucson, AZ
    Goodluck!
    Stinkeye member 520
