Crank bolt question?
Results 1 to 6 of 6
This is a discussion on Crank bolt question? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I'm currently doing a timing belt replacement and i put the new belt on and tried to rotate the crank ...
    Jan 2014
    I'm currently doing a timing belt replacement and i put the new belt on and tried to rotate the crank bolt over twice to make sure everything still lined up, well half a rotation into it and it won't turn the pulleys anymore and just tightens the crank bolt. did i put the belt on wrong? did i put the tensioner on wrong? i tried putting it in higher gears and nothing. it just continues to tighten itself. Just really frustrated and stumped right now
    Jan 2014
    its on a 07 wrx
    Please clarify.
    The crank bolt is attached after installing the crank pulley. You did put the crank pulley back on, right?
    The instructions say to clean the crank threads, oil the bolt threads, and then torque to the low torque spec before torquing to the high torque spec (I don't have the specs on my mobile sorry).
    What are you doing? Is the bolt just spinning "loose" even though the car is in gear or what?
    Edit: I've given it more thought. This is what I did: put the crank sprocket (if you removed it) AND the crank pulley (you certainly removed it) back on. They are indexed to only go on correctly.
    Clean the bolt and threads up as above. Put the car in gear and have someone step on the brakes. Tighten the bolt but you don't have to go to the full torque. Now take the car out of gear, put it in neutral. Rotate the motor from the crank bolt.
    If the marks are OK, remove the crank bolt and pulley, replace the timing covers, then put the pulley back on.
    Torque the bolt in two steps. For the 2L 2002 motor I first went to 34 ft lb then to 94 ft lb. to do this, put the car back in gear and have someone step on the brakes.
    Is this what you did and if so what problem are you having?
    Moderator Donkey's Avatar
    Da boonies,Va
    You should be turning the motor with the transmission in neutral.
    2002 FORESTER S
    1998 FORESTER S
    Definitely! Put the car in neutral to turn the motor manually!
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Sounds effed up. Probably the timing is off and you hit a piston to valve. Re-check all the marks... if engine will not turn all the way it's a serious issue, don't force it, rather take back apart and start over.
