Windshield washer Fluid
Results 1 to 4 of 4
This is a discussion on Windshield washer Fluid within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Anyone know what the mixture is of the solution that subaru sells to enable you to have washer fluid that ...
    Jan 2014
    Anyone know what the mixture is of the solution that subaru sells to enable you to have washer fluid that never freezes local stores only sell freeze point up to 32 degree Fahrenheit I want to mix some up myself .
    For External Use Only irickchad's Avatar
    Sep 2013
    WV
    Mix 1 gal Distilled water with 1 bottle of "Heet".. it's methanol, and the same difference, but surely somewhere in your area sells premixed -20 if you need it.
    1000 ml water
    30 ml white vinegar (or 30 ml 5% acetic acid)
    4 ml liquid dish soap
    60 ml isopropanol (or rubbing alcohol)
    Do two things in parallel: test first overnight on a non-visible area so you know it won't damage your paint; also leave the bottle outside overnight so you know you have enough isopropanol in the mix to prevent freezing. Then act accordingly. If your climate is cold enough you can simply test the bottle in your freezer, which with any luck should be around -20C anyway.
    Not responsible for any damages or injuries. You do this at your own risk.
    BTW, if you want to know the actual contents of the Subaru stuff, contact Subaru and ask for the MSDS. It may not have proportions but it will have contents.
    Sep 2013
    WV
    Or if you're not walter white you could just make the kind I said, hahahahahaha
