Possibly bent valves? Or normal 2011 WRX Ticking noise?
Results 1 to 15 of 17
This is a discussion on Possibly bent valves? Or normal 2011 WRX Ticking noise? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Please, please, help! Long story short is, I bought a 2011 WRX that got in a collision where the frame ...
    I'm engaged to my WRX. kedonot1's Avatar
    Oct 2013
    Syracuse, NY
    Long story short is, I bought a 2011 WRX that got in a collision where the frame crushed the timing belt covers. The guy who worked on my car said that the timing belt had 2-3 teeth shredded. He said the PSi on the cylinders was 130+ Psi, and he may be concerned about the engine... but I decided to take it home anyway.
    After I got all frame work done, and new timing belt and covers... I started it up. I've never owned a WRX before, so I don't know if my engine is shot, or if the WRX is suppose to sound like this.. but It's a consistent ticking noise..
    It idles at 1500 rpms, right at startup. Than it starts slowly dropping to 500-700rpms and starts to sound like it's gonna stall out. I also live in new york, and it's 20 degrees outside..and my car hasn't started probably in 5 months... When I rev it up, the ticking noise gets faster and doesn't seem louder. But reving it up doesn't make it sound like a "Growl" in the exhaust, it makes it sound like a honda civic...but when it goes back to idle, it has that growl sound to it. Also, the car started to shake when reving it a little at 2500rpms.
    Please help, what should I look for? Maybe a tensioner? Maybe it's normal? Maybe I'm just a first Subaru owner.. or what?
    I been researching like crazy, and I keep seeing that it's either... normal... or bent valve play.. or a spun rod bearing.
    Here's a video of it..
    Need help diagnosing check engine codes? Just message me!
    Aug 2012
    Tucson, AZ
    It sounds a little loud but it could just be the distortion from the video. Other then that it sounds pretty normal to me. If you're that worried though I'd take it to the dealer and have them double check
    Oct 2013
    Syracuse, NY
    Quote Originally Posted by nsibanez View Post
    Yeah, I have people who tell me on another forum that it sounds normal..and than i have people telling me that my valves are bent.
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    If your compression is good on all cylinders the valve HAVE to be ok. A bent valve will kill compression, even a bit of bend will do it.. Do a compression test. And that should settle this one...
    Palmyra, NJ
    Honestly sounds a lot louder than normal to me...You should hear more rumble from the exhaust than ticking. Valve ticking is normal, but not that audibly. I wonder if that's just a result of the acoustics of your garage though...tough to tell.
    Aug 2012
    Tucson, AZ
    Ya like I said it's hard to tell if it's louder then normal or loud because of video distortion. The newer Subies don't have much rumble with stock exhaust..theyre quiet
    Also if a valve was bent it should idle pretty hard
    Moderator Donkey's Avatar
    Da boonies,Va
    A leak down test will easily show a bent valve issue.
    2002 FORESTER S
    1998 FORESTER S
    Mar 2012
    Sorry, but a compression test is all it takes. Bent valve will kill compression. Leak down only confirms that piston rings are good, indicating the leak is the valve. Since the question is about bent valve... I'm not convinced leak down test is the solve-all and would advise for compression test first.
    Palmyra, NJ
    First rule of ClubWRX, you don't disagree with Donkey
    Mar 2012
    Trust me, I didn't do that lightly. I did try to think about it first....
    Palmyra, NJ
    Quote Originally Posted by Ingo View Post
    I know what the tests are but not enough to make an informed opinion, so whatever I say is here strictly as a page filler
    Da boonies,Va
    A leak down does more than just tell you the pistons are sealing. In fact it can easily tell you,if it is a valve issue,if it is on the intake or exhaust side. A compression test won't pinpoint the issue. It just tells you nothing more than if you have compression or not. It is a dynamic test where a leak down is a static one.
    2002 FORESTER S
    1998 FORESTER S
    Mar 2012
    Point being: if there's compression = valves are good + pistons are good. If either fails then the engine needs to be opened up. Otherwise it's likely to be a valve clearance issue, too much play causing the noise. I'm not sure I have the right words, valve clearance may not be correct terminology, it comes from the "old times" where pushrods and rockers opened valves... Now there's a shim under the cam, it's thickness determines the "play"...
    Registered User AFP520's Avatar
    Aug 2005
    NJ
    I am not an expert mechanic and I do hear the ticking on my car, but not quite as loud as this. Take another vid outside of the garage for comparison.
    '14 SWP STI
    Aug 2012
    Tucson, AZ
    Double check to see if our valves are even adjustable. A lot of cars are self adjusting.
