Small Problem
Results 1 to 8 of 8
This is a discussion on Small Problem within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Only on start up when I turn the key it starts and revs up to roughly 1500 like it should ...
    Registered User SilverSemoWrx's Avatar
    Oct 2013
    Jackson Missouri
    Small Problem
    Only on start up when I turn the key it starts and revs up to roughly 1500 like it should then drops and Boggs down and almost dies. I just recently went with a stage 2 tune. Could this be a fuel pump problem?
    ~2004 Subaru Wrx - Stage 2
    ~2013 Honda Civic
    -I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming.
    -Nobody remembers the guy who finished second but the guy who finished second.
    -Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    When you turn the ignition on (before actually starting) do you hear the fuel pump going? It usually builds up pressure then quites until pressure drops and it starts back up. Since it has fuel pressure to start and go up to 15oo rpms, I suspect it's not the fuel pump.
    Palmyra, NJ
    Could be a ton of problems...but yes. Fuel pump could be bad...or something as simple as clogged fuel filter.
    Clean the MAF sensor as well.
    Mar 2012
    Fuel filter is entirely possible, so is MAF and a number of other causes. Once I blew up my intake tubing, the engine started just fine and then immediately died dead. And that was perfectly repeatable. Once I had things plugged back together it worked like it always has...
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    IAC valve. check it.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Oct 2013
    Jackson Missouri
    Where might I find the IAC
    ~2013 Honda Civic
    Registered User ElusiveSAV's Avatar
    Jun 2013
    PA
    When you originally flash, your ecu has to relearn to idle, this is common for first 10 mins, after that if there is a probelm then I have no idea & talk to those guys ^^^
    Aug 2012
    Tucson, AZ
    Iac should be located on the throttle body. Clean that as well. If you remove it replace the gasket as it will expand when removed and cannot be re used
