Dealer 30k Mile Service a rip off?
Results 1 to 15 of 16
This is a discussion on Dealer 30k Mile Service a rip off? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Title basically says it all, my car is about 2k from 30k and was wondering if it is worth it. ...
    Registered User pbart617's Avatar
    Jun 2012
    Title basically says it all, my car is about 2k from 30k and was wondering if it is worth it. The main thing I'm concerned about is getting the tranny fluid changed.
    My question is should I just do an oil change and tranny fluid change, instead of the 30k service.
    Thanks in advance
    Sent from my DROID RAZR using Tapatalk
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Look at what is included in the service. If you can't do all the items listed (and document that it was done), then have the remaining items checked off by the dealer.
    Registered User poi88's Avatar
    Feb 2013
    Long Island, NY
    But it seems sometimes the dealer performs additional services ? For example my manual says oil change at 7500 and nothing else yet the dealer runs a whole bunch of tests etc service fee 160 dollars (the test are probably good to do if not done at home I would assume) but the impression I get is that it wouldn't void warrantee if only an oil change was done ? Correct me if I am wrong ...
    The warranty is an agreement between two parties. If you are in the US you can do the work yourself provided you keep proof it was done. The work is exactly what's in your manual.
    What I think should be done, what the dealer thinks should be done, and what you think should be done are not relevant. What is written in your manual is relevant. I suggest you follow that to the letter.
    If in doubt get clarification in writing from SOA.
    - Al Stewart
    Contributes Nothing ShiftingLanes's Avatar
    May 2013
    Riverdale, NJ
    Quote Originally Posted by poi88 View Post
    Correct. Not doing a service like this at the dealer would never void a warranty. If you do only an oil change, that's fine.
    I'm really unsure if the 30K service is a ripoff. Yes dealers are more expensive than doing the work yourself or taking it to your local Jiffy Lube. However, in my opinion, when you have a car that you are into like the WRX/STi community, why chance anything. If you have a Civic or Carolla or Focus, sure, skip the extra stuff because they're more reliable cars and have less finicky engines and parts than our rally-inspired, sports sedans/hatches. For me, I will gladly pay the premium to have the extra tests done on my car. It might be more money, but I certainly do not view it as a ripoff. It's paying for piece of mind. Yea, they could miss something, but you or Jiffy Lube could as well.
    http://shiftinglanes.com
    '14 DGM WRX Limited Hatch
    I'm a build thread?
    Stink-eye Mob #49
    The Corolla is a better car tan ours.
    - Al Stewart
    May 2013
    Riverdale, NJ
    Exactly. Which is why I'd recommend what you said above. Do the full 30k service.
    Posted from my mobile foruming mah-sheenz
    I'm a build thread?
    Stink-eye Mob #49
    Jun 2012
    Yeah my thoughts are just to do it. I have had the 15k service done by the dealer. My thoughts were to just do this one as well, but wanted to get some opinions from you guys
    Ah ok I see.
    When going to the dealer it might save $ to have them do the book list and not allow extras.
    - Al Stewart
    Feb 2013
    Long Island, NY
    Higher volume vehicle, massively higher design budget, more practical, better value, probably more reliable, but I know what I would rather drive , signed #1fanboi -
    ( yes I think more reason for more thorough servicing
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Well, we could debate the "more practical, higher value" aspect, but let's leave that.
    OP: it's your car, you OWN it. There's several ways you can go about maintenance/repairs. Each has it's own good/bad points. IF you're good at wrenching you can do virtually everything that needs to be done. If you would rather keep your hands clean and don't mind spending the money there's nothing wrong with doing to the shop. A certain degree of maintenance is required or it'll come apart at the seams. Extra "tests" shouldn't be needed unless there's a CEL or some abnormal indications. If you asked for something outside the scheduled maintenance (like "please check the cabin heater...") you're open to additional cost, of course. Otherwise I'd tell them to stick it somewhere else...
    Jun 2012
    I got ya. I really appreciate everyone's insight on this. I might just have them do an oil and tranny fluid change. Seeing how everything else I can do myself. I have free oil changes through my dealership, so until they run out I will continue to take it to them. Tranny fluid I have not done before so it might be better to take it to them. Unless it is not to hard?
    Any opinions on this?
    Mar 2011
    FWIW dealer service is a ripoff. take a look at the maintenance schedule for our cars:
    2011 Subaru maintenance schedule and new car break-in period
    it doesn't even say to replace the fluid. with that said, i had my fluids changed at 60k during the spark plug change at my local tuner.
    Palmyra, NJ
    I'd personally never spend all that loot for the 30k service. You can change fluids yourself. "Inspect" everything else yourself that they charge a couple hundred bucks for...and order a cabin filter off Amazon and change that yourself which saves $100 alone...Totally not worth it.
    Registered User jsantos1082's Avatar
    Aug 2012
    River Edge, NJ
    do it yourself man
    JOE
    2013 WRX DGM
    Stink Eye Mob #82
