need helpful advice.
Results 1 to 14 of 14
This is a discussion on need helpful advice. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey guys, after researching i have found very little. I pulled plugs on my 04 rex, found that cyl 3 ...
    Registered User tsize4's Avatar
    Dec 2013
    Thumbs up need helpful advice.
    Hey guys, after researching i have found very little. I pulled plugs on my 04 rex, found that cyl 3 plug was somewhat lean (white) . Cyl 3 is having a misfire and i found a vac leak a bit ago. ( probable cause of lean plug) . I bought the bkr7eix ngk iridium -11 plugs. I am currently running 23psi peak boost with stock injectors and fmi. Yes it has been tuned in october. My queation is, if im running 22 psi what should my plugs be gapped to? Since stock is .028 - .032 at 14.5 psi should it be smaller for more power? And also anyone know the specs for tourque on the plugs? Thanks
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Quote Originally Posted by tsize4 View Post
    I'd be looking at a fueling issue rather than a plug problem. If your injectors are stock with a ton of miles on them, chances are they are partially clogged. If you are running the stock injectors, you are on the ragged edge of size anyways. What Fuel pump do you have, and when was the last fuel filter change?
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Jul 2012
    Rocky Top
    ^This,
    or
    Have you considered upgrading to larger injectors? And maybe a fuel pump. Would give you a lot more wiggle room.
    Dec 2013
    Quote Originally Posted by 06wrx4me View Post
    Thanks for the replies, the car has 90,000 on it and i bought it used. As far as i know the injectors and pump are stock. As far as fuel filter idk, that was my next step. I was also thinking something wrong with the tune
    Jun 2006
    Nor Cal
    Yeah you got fuel system issues. I bet your injectors need to be removed and cleaned, your fuel filter needs to be changed and your fuel system cleaned. But if I was going to go through that effort and pay to have the injectors cleaned, I'd just put new bigger injectors in and get a reflash.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Dec 2013
    Only cyl 3 is misfiring. Weird. Will seafoam through the tank help anything until i can remove the injectors?
    Jun 2006
    Nor Cal
    On that cylinder the injector could be clogged the most. Too little fuel in that cylinder is causing the excess cylinder temps, detonation and CEL, which can lead to ring/ring land cracking or a hole in a piston. It may be too late already, but I hope not.
    Seafoam couldn't hurt, but at the risk of causing further damage, I'd park it until you can get the injectors taken care of. If you crack a ring land or ring, you create shrapnel that then takes the head out. Then you're looking at a rebuild and between $3000-$7000 in work depending on which direction you go.
    You can send the injectors out to have them flow tested if you want to see how bad they are. You can also pull the #3 plug out and bore scope the cylinder to check for any damage.
    These cars aren't a cheap toy, don't skimp or cut corners.....they'll bite.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Dec 2013
    Any idead what this connector goes to? Passenger side wired in with the connectors to the o2 sensors
    Jun 2006
    Nor Cal
    Take another pic Zoomed out farther
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Palmyra, NJ
    It's got a resistor in it. I'm guessing that's for the sensor in the Uppipe.
    Jun 2006
    Nor Cal
    Didn't see the resistor at first glance, I concur.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Registered User scoobaru03's Avatar
    Dec 2009
    D.C urea, Maryland
    Get bigger injectors and a fuel pump and a tune your not putting enough fuel in there!
    2003 Impreza WRX Sport Wagon
    "I wouldn't want to belong to a club that would have me as a member." - Groucho Marx
    Is it fast? I don't even know if its street legal. O.o (IROC-Z)
    Dec 2013
    Sorry guys didnt see your posts. As far as what we talked about, i swapped the fuel filter and upon initial start it ran very smooth. The later in the day at idle my wideband was giving me readings of ~16.6 and cel flashing. Cyl 3 misfire came up again along with po171 sys 1 too lean. Checked for leaks didnt find any. Since then it has went away but coming down to idle it starts to idle creep and find proper idle, dash lights flicker for a second. But still has rough idle and misfire. I am leaning towards a injector on cyl 3. What do you guys think?
    Dec 2013
    ^ ^Reguardless i am going with the walbro 255 and pink injectors. It was tuned back in october but it can hurt to be retuned.
